Fuel Evap system
hope this helps,
O.
hope this helps,
O.
If you top off, fuel can find its way to the valve and make it stick. It can be cleaned with carb cleaner, that said I have only done this on an older W210 and don't know exact location of the valve on a W211.
Ok, there is another place to check. Just take out the rear wheel from the passenger side, then take out the plastic cover that protect the area there, you will see big black cylinder, just check that the hoses are fine and you have none of them un plugged and you may want to check that stupid cylinder too
