I 1/4 miled it last night
#51
e55
What i did since slips posted in first post:
- bolted on vrp shorties - there is a leak somewhere so not sure if Im getting max power
- sanded down the innards of my 16" rim because I noticed marks from the caliper so they had to have been touching and causing resistance
- grille removal
- jacked rear suspension only
- aligned the suspension - always had the wheel cocked a little to the left to go straight, now its straightened out. MPG shot up too, so there had to have been some drag
traps went from 115.8 to 118.3.
- grille removal
#53
Registered User
- grille removal
- grille removal
#54
e55
UPDATE, went tonight:
- Fixed exhaust leak at driver side header/stock exhaust flange
- Put on the s55 Air snorkel
- Stock TB grind mod
Best was 11.71@120.03![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
60' was a 1.75
Slip is in the car, which car died while driving back, and is abandoned- I think its the alternator. Cant hold power, headlights go out, ESP malfunction, Brake malfunction, no radio, no defroster.
60' was a 1.75
#56
e55
This was in manual mode by the way: my car doesnt hit the limiter in manual, but when I did the sneaky ecu reset one time, I noticed the shifts were faster in manual, than it was in sport.
So that run was in manual mode and I was pleasantly surprised.
#63
This is back when I have the RennTech 168mm pulley, RennTech tune, Headers, custom intake, and 82mm tb. Also, my car is 87K miles and in 85 degree weather. I have not have a chance to run my car since the retune and 180mm pulley yet. Hopefully soon.
#65
#67
2003 porsche 996 turbo
these wheels are all over shouldnt be hard to find them
just a quick search on c/l for the nashville tn area.
http://nashville.craigslist.org/pts/1877575028.html
#68
Strong run AWOL! Congrats.
Not to thread jack, just so everyone is aware, those CLK 16" rims are not a direct bolt on for the E55. They need a little modifying, special lug bolts and spacers to work on an E55.
#70
thats some nice 60fts,I need to get my drag radials on soon.
I broke 93 in the 1/8 but had a 2.2 60ft on stock street tires.Ill be hitting the track again this wed to see if I can do any better.
