wheel alignment After lowering
Old May 20, 2010 | 01:41 PM
AUS-E55's Avatar
CLK-63 BLACK/2014 E63S/2013 ML350
Does anyone have any to go by alignment specs for the E55 after lowering,
I'm going to install the crash bolts before taking the car somewhere to get the alignment done and would like to see what specs you all are using for a lowered car.
Old May 20, 2010 | 11:28 PM
jangy's Avatar
2015 S212
I would target the cambers to be at about -2 to -4 degrees and consider going slightly toe out for wear or neutral for feel.
You won't be able to adjust too much without replacing arms and it depends on how much you lower and what size diameter tires you are running.
Old May 21, 2010 | 11:53 PM
AUS-E55's Avatar
Thanks jangy
