Which fuse is switched with the key?
Looking at the fuse box located in the left side of the dash (the one accessible through the snap-in panel you see when you open the driver's door), which one is controlled with the ingition switch?
I can find constant live power, but I need a connection point in there that is switched on and off with the key.
Thanks.
Thanks.
