Rim Spec Question
Old May 25, 2010 | 07:38 PM
MoeMZA's Avatar
Rim Spec Question
Anyone fitted their e55 with rims with these specs below? If so, any issues, rubbing, brake fit, etc? Also, would factory stock tires fit onto the specs below being that stock tires are for 8 and 9 width rims?
Specifications:
Size: 18x8.5 Front / 18x9.5 Rear
Bolt Pattern: 5x112
Finish: Silver Machined Face
Offset: 30 Front / 35 Rear
Hubcentric
Old May 25, 2010 | 07:54 PM
BenJ's Avatar
2003 E55 AMG
Specifications:
Bolt Pattern: 5x112
Hubcentric
Those should fit and yes, you can run the oem size tires as well, but you can go a bit wider as well.
Old May 25, 2010 | 10:08 PM
MoeMZA's Avatar
Thanks... I need new wheels badly.
