Drag Day at Fontana, CA - tomorrow!
For whatever reason the paths we both took lead to failure and excessive cost. Call it what it is but at some point you need to draw a line and stop spending. You could probably spend another $20K chasing Max Power, but is it really worth it?
At this point just suck it up and get a safe decent tune and call it a day. Run the F out of it like that and start to enjoy it like it is for what it is.
I only feel obliged to post as what you have written is not accurate.
It is disappointing that you would choose to characterize our work in this manner. You know that we have 50%+ more time in your car than we billed you for. Truly, no good deed goes unpunished I guess.
For the record, your car has major issues. The quality or work done and the parts chosen leave you in a bad position. Additionally, your engine was on FIRE.
As we discussed and I showed you, your entire engine harness was melted. There are frayed wires, exposed wires, melted connectors, etc. You NEED an engine harness to fix all the electrical problems, but seem reluctant to accept that and buy one.
Specifically, the $2400 for an alternator is totally BS. That included diagnostics and repairs of parts of the wiring harness, fixing the melted plugs on the alternator (as the new plug would not fit on the harness as the plastic was melted from your fire), leak down/compression tests, valve cover gasket, diagnosing for multiple vacuum leaks and repairing as we found them, etc. This was a significant amount of work
When you left that car was running better then ever you stated, and I personally drove it. Even in this post, you say the car is running fine! Well, it was not running fine when it came to us, and now it is running fine, yet you still have "lost confidence" - this I am confused by. If it is because we will not fix it "cheap" and "dirty" then I agree we should part ways. This is not going to help you or us.
I spent HOURS with you on the phone and in person discussing options and the condition of the car.
You left saying you were going to do more work, if you had "lost trust" why would you not contact me?
It is sad, but it seems that this is a continual problem with you. You seem to have expectations that are unrealistic. You want someone to repair your car QUICK, yet it has problems you wont repair and you are asking people that (1) did not build it and (2) don't do things in the manner in which your car was built. This is an untenable situation. It takes time to diagnose, undo all the work that is not up to acceptable levels, then start fresh to achieve your goal.
That being said, I still think Robert should not give up. His car has potential. Ahmad's car is evidence of that. He is able to consistently run 10s with less mods and relatively low boost in an older platform.
As Robert previously posted, the shoddy install by Vadim w/Injector/fuel/lines/pump etc = near Pyromaniac barn burner under hood while on the Dyno that almost took the Dyno shop down w/it. I can't believe you haven't replaced the "Kentucky Fried" wiring harness
yet STILL trying to proceed w/final tuning & MAX boost.
I said this to someone else regarding your car, it's too poignant not to repeat. Brad, "Let the ship finally sink in someone else's harbor."
After hearing Evosports side & reflecting back on Roberts history w/ALL tuners, he's obviously been thru literal hell n' back w/Vadim alone & now @ wits/monies END w/Christine errr whatever he calls her @ this point...
Burn it TWICE, ditch it, it wont die (as long as you keep throwing $$$ into her that is) Drive the **** outta it in present form, or let it go for crying out loud
When Vadim installed my Kleemann SC, he somehow snapped the fuel rail while trying to bend it so instead of replacing it he decided it would be cheaper/faster to just use high pressure hose.
When he put the car on the dyno at Powertrain Dynamics (next door to Evosport), the fuel line burst (due to the loose clamps) at over 100psi and set the engine bay on fire. The dyno owner/operator told me the flames hit the celing of his shop. He tried putting the fire out with his fire extinguisher but the fire was so stubborn and violent that the techs at Evosport heard the noise and ran over to help. They brought over more extinguisers and finally put the fire out. Steve was so pissed off at Vadim for almost burning down his shop and vowed never to dyno Vadim's car again and pushed my car out of his shop.
Vadim later mentioned to me that he needed me to pay for a new set of fuel rails and that the hoses he used did not work. I asked him why and he finally told me that there was a small fuel leak caused by hose. He never replaced or repaired anything caused by the fire so when I picked up the car I was shocked to see the scorched engine bay. He said he would take care of it which we all know he never did.
The results of that fuel line fire (not the July 4th shop fire) is haunting me to this day as just about every electrical component is dying prematurely. First it was my car alarm, then the cam sensor, MAF sensor, crank sensor and now battery and alternator. I drove the car home today from Evosport after they fixed most of the issues but the CEL came back on and this time the MAP sensor is dying after I scanned the car.
All the wires were either dry, cracked or exposed or shorted out due to coming in contact with each other or grounding on the body of the car. The wires in the ECU box was a complete hornet's nest and caused 3 fuses to pop as exposed wires were touching each other.
Their were also numerous vacuum leaks, air injection leaks, etc...One hose was not tied down and was rubbing against the alternator pulley until it was completely severed causing a massive EGR error. Other hose connections were too loose or JB welded with no professional clamps or ties.
The work done by Vadim's crew was sloppy, careless and quite frankly INexcusable. I talked to Vadim and he thinks Evosport is just running up the bill on me and that the car was running perfectly when I drove out of his garage.
While I admit the car ran fine and I even took it to Renntech/DynoComp in AZ for a dyno which yielded good results, Vadim struggled to get the car to run right unitl he replaced the cam sensor, crank sensor and MAF sensor and even alarm siren. I don't believe all the OTHER electrical problems started creeping up until now such as the battery and alternator dying. Tonight I discover that the MAP (Manifold Pressure Sensor) also died due to the electrical short circuits and damaged wire connections.
In summary, if you EVER choose a shop to work on your car MAKE SURE that they pay attention to detail and are organized. I've been through hell with this car and the companies I've dealt with until Evosport now maybe DynoComp in the future.
I told you it MAY go away an it may never go away with that harness. As the harness is so mangled it is impossible to diagnose any individual sensor issues.
I have a new sensor for you here as I told you. But in my attempt to save you money we did not sell it to you until we had more info to know if that was needed.
I am empathetic for you. But when you start to bash my business without telling nearly all the facts I take issue.
Brad
Brad
Edit: I just noticed some fresh oil stains on my driveway. I think the head gasket you installed is starting to leak again.
One more thing. The "Hot" Air intake is made of Stainless Steel which reflects almost all of the heat away instead of letting it enter the air pathway. This comes from an automotive engineer with 25+years of experience who has worked at the big 4 for decades although I don't know if what Vadim insisted upon is true either.
If you want a car that can run at least 1 bar PSI and drive like stock etc run low 10s ... get a porsche turbo and mod that. Your asking way too much of that C class platform.
I just want to break that record one way or another and move on to another platform. My mission is to make the impossible possible whatever it takes.
As I said before...Either I break the overall record or I break the car completely and call it a day and I want to do this before March of 2011. Because I'm basically going to sell this car out of state before the CA smog inspection date comes due by September 2011.
If you're planning on breaking any records in March, don't count on it being in a California track. In March, most tracks here are in the 80 F range if not higher unless you don't mind a 1500 to 2000 ft of DA disadvantage (not saying it is not possible to break records at that DA but your runs won't be optimum). Or you can always try an MIR track rental, which (luckily for you) they always happen to have one in March as well.
Optimum conditions for California tracks are usually from November to January (and in very rare cases February). So if you are still planning to break the MB record in California, try to aim for November/December.
You want to break the record then just buy my car. It will break the current overall record in decent DA
but if you break it and the car is not broken afterwards we can talk.Besides I guarantee the Cavs will win a Championship before Lebron does.
My money says you're wrong
Dude - you sound like the biggest nightmare customer EVER. I wouldnt work on your car if you agreed to pay $10k/hr.
