Drag Day at Fontana, CA - tomorrow!
Old Jun 4, 2010 | 06:55 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Heading out to the strip tomorrow morning. Anybody interested?
Old Jun 4, 2010 | 06:57 PM
bassn_07's Avatar
2006 E55 AMG
Good luck Robert! I'm sure this is a long awaited day for ya and I hope all goes well.
Old Jun 4, 2010 | 07:00 PM
mikekuriger's Avatar
2010 C63
i want to go! but sadly, i'm having a gtg at my house tomorrow. damn!!
Old Jun 4, 2010 | 07:07 PM
AMGSC's Avatar
Yeah finally decided to baseline the car in 90F weather but better late than never. The ETs will not be too good due to 1200 elevation and high humidity but it's the track I ran at last June on two damaged pistons at 12.5 ET/116 trap with street tires at same outside temps so I expect to do better than that. Problem is I'm running less boost this time on a lower compression motor so not sure how I would fare. I will go back on July 17th once I mod the car with 18-20psi and see what she does. Then on Oct 30th, I'm going to run it with direct port 200 shot nitrous.
Old Jun 4, 2010 | 07:56 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Best of luck. I was there last week and the DA was around 4,000 ft due to the air temps.
Old Jun 4, 2010 | 08:14 PM
blackbenzz's Avatar
haters crazy
Good luck tomorrow but you never come through on your timelines and I doubt this time will be any different. You have said you were gonna do this or that about a million times in the past and never did
Old Jun 4, 2010 | 08:47 PM
BenzoBoi's Avatar
Super Moderator
W221
Good luck
Old Jun 4, 2010 | 09:43 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Good luck, I'm glad you finally decided to test her out at the track
Old Jun 4, 2010 | 10:29 PM
2010 C63
what tires are you running?
Old Jun 5, 2010 | 02:26 AM
AMGSC's Avatar
MT DR's 15 x 255 rears if the wheels clears my Brembos.
Old Jun 6, 2010 | 12:13 PM
blackbenzz's Avatar
haters crazy
Results?
Old Jun 6, 2010 | 12:59 PM
bassn_07's Avatar
2006 E55 AMG
Originally Posted by blackbenzz
Results?
I've been waiting and looking for results since last night..... I know conditions must have been horrible since it was almost 90 degrees here in San Jose. Robert....come out come out from where ever you are!!!!
Old Jun 7, 2010 | 05:54 AM
MB_Forever's Avatar
Any updates here yet?
Old Jun 7, 2010 | 09:49 AM
blackbenzz's Avatar
haters crazy
Surprise! No updates lol
Old Jun 7, 2010 | 12:11 PM
rarfinancial's Avatar
CLS63
Did any one make it there?
Old Jun 7, 2010 | 12:16 PM
CLS63
Unless it at least 105 degrees out there I'm not going back
Old Jun 7, 2010 | 12:38 PM
JamE55's Avatar
Out Of Control!
It's like this.
Blackbenzz = Chris Rock
AMGSC = Kobe
Don't bother me Chris. Can't you see I'm tryin to concentrate on my 1/4mi goal!
Old Jun 7, 2010 | 01:51 PM
BenzoBoi's Avatar
Super Moderator
W221
Old Jun 7, 2010 | 07:43 PM
MB_Forever's Avatar
Robert, so did you ever make it to the track? Post your times if you did.... don't worry if they're good or bad as these are only a baseline and maybe we can help you improve them
Old Jun 8, 2010 | 01:02 PM
Benz-O-Rama's Avatar
I'll bump, so Ahmad doesn't have to do it.
Old Jun 8, 2010 | 02:34 PM
Vic55's Avatar
Administrator
Old Jun 8, 2010 | 07:55 PM
AMGSC's Avatar
Results?
Sat morning I went to discount tire to get my drag wheels/tires mounted and to my dissapointment, the wheels won't clear my Brembos.
Instead I had them check the alignment and found out it was completely off. Vadim never did the alignment after installing the camber, caster and toe arms! The fronts were -.45 and +.68 while the rears were both toed outwards causing my Conti's inner tread to completely wear out after only a few thousand miles.
So instead of going to the track, I ended up getting an alignment for smokin deal of only $89. The car now steers completely straight even if I let my hands off the wheel for for 30 seconds while cruising at 40mph.
It was way too hot anyway! I'm bringing my car to Renntech/DynoComp for the tune with both modified pullies this month and should at Sac for the Wed night drags at least twice in June or July. It's cooler at night and Sac has better DA and trap speeds.
Old Jun 8, 2010 | 07:59 PM
AMGSC's Avatar
Anybody interested in a set of 16" light MB wheels to mount your MT's on? As long as you don't have oversized brakes. you should be OK. I got them from a fellow forum member for $500 I think but I'll let them go for $300 including shipping.
I'll post some pics when I get home.
Old Jun 8, 2010 | 08:34 PM
Thericker's Avatar
V12-Biturbo
Not to be a nut cracker but you can buy (2) lightweight 13.7 lb MB 16" drag wheels absolute MINT condition off Ebay DELIVERED to your door for $300
Old Jun 8, 2010 | 09:15 PM
AMGSC's Avatar
These are in mint condition also. I'll let them go for $250 delivered just to speed up the sale.
