Big HP fuel problems (pic) Solutions?
I have been searching the boards and there seems to be limited, and somewhat contradictory, info out there.
I am having trouble chasing my lean gremlin and would like a bit more info before I start throwing parts at the problem.
Thanks.
These ECU`s have some crazy adaptive programs though.. Like a brain of thier own..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
If you need way huge injectors, you may have to play with supplemental injectors or variable fuel pressure.
This appears to be the fuel filter/sender under the drivers side rear seat:
This one seems to be the fuel pump assembly under the passenger side rear seats? It looks as if there may be two pumps there???
Anybody have part numbers for the filter or pump(s)?
Subscribe here: http://epc.startekinfo.com/epc/subscribe.jsp
Choose the free option and give them your credit card, they wont charge you. You will get an account and a password, and will have to renew it again in a year.
If your computer/browser doesnt have Java runtime, then google is your friend, install it.
Login at http://epc.startekinfo.com/epc/login.jsp, and launch the application. Enter your VIN for quickest access to parts relevant to your car's model year and options.
Been spending time on this forum for awhile now and honestly never knew this was available. Already been there and subscribed, what a valuable resource.
Sorry, back on topic...lol.
Hadilaw just texed me and said that puppy for the e55 is 350.00 bucks shop cost!!! Ouch! This E85 crap can assist in eating up seals , gas tanks and other stuff too.. At leas that is the rumor..
I can tell you that mine filter poured out nasty black gas! 50k miles and I am carefull where I fill up.. I only use Shell and stick with semi new stations..
Mine was 40 bucks list and 10 minutes to change.. The CL got a break finally on something..
Fuel filter is a damn important part on these modified engines, so don`t overlook it.. I am kicking myself for not checking it and for assuming it was changed on my motor rebuild..
www.ultimatepd.com
sorry for the pics, I didn't have a scanner available.
On of the words blurred out by my flash, is "Modified"
Fortunately all 55's use Bosch ME 2.8 ECU's which have enough flexibility to adjust idling if a slightly larger injector were to be used.
Though tuning would still be required to properly dial them in.
Anybody have experience with this?
Just recently I witness a E55 having huge fuel issues with the car going extremely lean at the upper RPM's. Once the fuel system was replaced with factory parts fuel was no longer an issue. His fueling problem was a 10x worse than mine and honestly believe this will fix my problem.
Here's a log of one of my runs. This was done late last year with a mix of 91 and 100 Sunoco oxygenated race fuel. You'll notice that the fuel pressure is 65 psi at the top of 3rd.
