Big HP fuel problems (pic) Solutions?
If this data log was with the colder S/Ps, then It looks good. But with your other warmer S/Ps , I think you would have been in the Danger zone , on a speed 1 mile run
As you know I let my Car set for 3 years, The fuel system & Tank was really gunked up . So I took on the task of Cleaning it . The pumps were locked up, Freed them with Snap-on air motor oil. It has Oil of wintergreen blend. I also found the fuel pick up screen , Cracked. UGH. And you know you just can not get the pick up screen , you have to buy the big dollar fuel module. So I took the pump off the outside of the module over the the Chevy Garage. They found a large Bag type push on Filter. 10X more filter area. It pushed on perfectly. This Fuel module is built buy Peerburg and is serviced as an assy. FOOLED THEM
Well ,Then I filled the fuel line from the fire wall to the filter assy , with a engine combustion chamber type cleaner. I let it sit for 3 hours . Then flushed it out with fresh gas . I then cut open the fuel filter. It was doing its job, ( CUT THE ENDs OFF) And Now you know the rest of the story. I could not have Jeremy tune my car with a Dirty fuel system. He spend quite some time getting the Rich fuel droup out the the curve. Buy the time i Finished this up The summer heat came in . Cheers to all _PTEngineering
This is with my standard plugs and right now with my one step colder plugs I'm seeing 1360 at the same RPM. My EGT's are even looking better right now with some of additional mods. When I get a chance I'll shoot you a file to read (just download the latest file from Zeitronix) and you will be amazed at how much better my new logs looks. If you noticed you could also see how that torque management comes into play in the TPS before every shift.
As I was saying this was done last year and since then a few things have changed. I'm now maxing out my fuel towards redline and need to have my fuel pump assy changed out to see if that resolves the problem. If not I'll be eager to see what some of these more informed members come up with....subscribing!!!!
Alan, thanks for the log file.. I could look at those for hours and they tell such a great story.. I have not had a chance to check my pressure, since the fuel filter change and port job on it.. I pulled one header back off to work on an area still touching the frame.. Should be back on the road this weekend and start testing the fuel..
PTE, I also cut my filter apart and will post a picture later on.. The CL filter is a large diameter filter and was only 40 bucks list.. Just had to open the inlet/outlet some to match system.. I think the 1mm port , was worth a 43% area increase..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
. Alan I figured you would have some useful insight. BTW do you happen to know the size of that fitting on the fuel rail?
After seeing what you guys have to say I think it makes sense to to start with replacing the sender/filter unit and see if that clears up the lean problem I am having (car has 48K miles). I ordered it and should be here in a few days. Can't hurt to clean the injectors as well.
Do you guys think I should replace the fuel pump assembly on the other side of the back seat as well, just to be safe? I am not sure of the cost of that unit, but sure it is not cheap.
Thanks!
Thanks!
twin (2) bosch 044 pumps (300l/hr x2)
2 bottom mount 8 an fittings feeding the pumps.
2 40 micron filters
3 8 AN fitting are now in the fuel rail, so I'll feed each side with its own pump the last 8AN goes to a Mallory rasing rate regulator adjustable from 30-100 psi.
6AN return line to the tank.
I just scored some 577cc injectors, there not in yet but they look very promising and in my typical fashion were very inexspensive.
I'd like to find some 650cc and be the first 55 on E85!!
For those that want to know, the stock injectors look to be stamped 386 and another stamp says 60. From what I'm told is that there high impedance 386cc & 60 psi. the math works out at our 80 psi setup. Still just guess though
2 40 micron filters
E85 runs cooler too so it should decrease EGT's and you can run more timing. Should be a monster!
Nice work though!
www.ultimatepd.com
Nice work though!
I was talking aobut making room for some larger rails , that can handle 800 plus rwhp.. See below..
http://www.mirrorfinishpolishing.com...UEL-RAIL-4.jpg
the filer and regulator
