parktronic and washers?
I have a question a found a bumper with the parktronic and washer holes but my car doesn't have either do they make covers for these or do i need a different bumper?
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Yes, I would purchase the right bumper cover for your vehicle. Although they can covers for the washer holes, but they attach to the washer jets.
Do you have covers over the washer nozzles, or just holes for the fluid to come through? because if you have washer nozzles, that pop out, the cover are attached to the nozzles. So you would need the washer mechanism. Call your local Mercedes dealer, for more information. I again suggest that you get the right bumper cover for your car.
I'm having the same problem with my e320 w211, I want to up grade the rear bumper, with the amg, but I bought the e63 rear bumper with park sensors, and I don't have sensors!!! how do I cover those holes???
CTSV/6sp Grocery Getter
Either buy the correct bumper for your car or install the sensors/washers in the bumper you have but don't hook them up. This way the holes are filled with the correct parts
Thanks for the reply, but you think the sensor have to be original?? Or I just can buy those on eBay for 25$, since I'm not going to use them, is just to fill those holes!! What do you think??? They will fit??
