supercharger chirp - when i let off?
e55
From what i read, this is not a standard chirp when the blower engages. Its more so, when I get off the throttle - I hear a slight "whistle", or "chirp". Its definitely from the SC though. Again, this is only when WOT, or when Im feeling frisky. If I drive around town subdued, its not there.
Anyone else experienced this? Or should I just bring it to the dealer and have them inspect it?
Guidance is appreciated
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
since it only happens after fast driving -- it is probably the ECU downshifting because it thinks you want the best/fastest gear --- and since you are slowing down it makes perfect sense --- To avoid this -- after fast driving and you want the car to be less aggressive -- upshift repeatedly --- even if the car is already in 'D' --- -- upshifting will tell the ECU you no longer want to play and want a higher more relaxed gear.
the car is simple preparing for another boost of speed - thus downshifting and chirping
e55
I appreciate the help, but I disagree with that hypothesis. Its only a new occurrence.
I shall get it on video soon and report back.
Its definitely belt related
03 E55 AMG - 01 996 TT
ive read a good amount about the chirp ...
mine chirps when i give it a good amount of throttle, and let off before i get to the goods ....
ive heard the only solution is to completely replace the supercharger, maybe the dealer will do it under warranty
there is a fix out for the older models that had this problem
from what i hear u need to replace them after a good amount of use/years etc
2004 E55 AMG
It's the belt slipping when the load is suddenly removed from it. If you snap out of the throttle(especially when doing a burnout), the belt will go somewhat slack since the crank slows down and the blower internals are still spinning at high speed. The kinetic energy of the spinning blower will try to pull the belt from the tensioner side, which will cause a loss of tension and the chirp. My car has consistently done this since I got it, and I've had 3 different belts on the car(stock, replacement, and 180mm pulley belt).
2004 E55 AMG
It's not going to hurt the engine, but there is the possibility ot could snap the tensioner if it bottoms out with enough force. The S/C Mustang guys have big tensioner problems. I watched my buddy shear his tensioner in half at the track when he let off after the burnout. With our cars and the travel/robustness of the tensioner I wouldn't worry about it.
you guys think that the supercharger clutch will be changed under warranty
i have the chrysler service contract ... they have done everything else with out a peep
