PLM headers Installed on a CLS55 -> +42WHP Dyno inside!!
Rating: Thread Rating: 5 votes, 5.00 average.
Old Jun 17, 2010 | 12:21 PM
Worth the wait's Avatar
2006 E55
I know its been done before, but.....
Originally Posted by KLR CLS
I am going to remove secondary cats and resonator and see what kind of a difference that makes too.
Any chance you are going to do a dyno with just the above changes? I am kind of somewhat skeptical this makes any significant power improvement. Are you going to use an x pipe or go straight thru?
Thanks for the info!
Old Jun 17, 2010 | 12:29 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Any pics ? What are primary pipe diameters?
Old Jun 17, 2010 | 02:12 PM
KLR CLS's Avatar
CLS63 PP
Originally Posted by skratch77
so this is with everything else stock right?Your sig says 82mm tb,was the tb on before the dyno?
Correct, no TB installed. The headers are the only performance mod actualy installed on the car( well and the HE, but not sure that adds any power). Other stuff has been in the trunk for months! No time to install, but will be corecting that next thursday.
Old Jun 17, 2010 | 02:17 PM
KLR CLS's Avatar
CLS63 PP
I will do a dyno after the mid-pipe upgrade, but I will be doing the pulley , TB and tune before that, so not sure how the numbers will translate to a stock car.I am going to use a custom x-pipe.
Old Aug 9, 2010 | 01:48 PM
witzerz's Avatar
e55
any updates ?
Old Aug 9, 2010 | 05:09 PM
KLR CLS's Avatar
CLS63 PP
Unfortunately I did not get a dyno of just the midpipe, but my next dyno with Midpipe, 185mm pulley and tune netted 500whp and 575WTQ so I picked up another 52 whp and 100 LB/FT with the heat soak rapidly killing power. Still more in her as I need to install the 82mm TB and Meth. Hoping for 530ish WHP and better then 600 Tq.
Old Jul 12, 2011 | 10:42 PM
  #32
BlackBeast'06's Avatar
'06 cls 55 amg, '03 Range Rover HSE, 88 Firebird Formula
Almost a year later....didn't the heat exchanger help with the heat soaking? Any new numbers to share with us?
Old Jul 13, 2011 | 12:28 AM
  #33
KLR CLS's Avatar
CLS63 PP
Nothing really solves the heat generated by the 185 and larger pullies, only recovery time is helped. I have some new tricks up my sleeve like a NX cooling kit with a tube and shell heat exchanger I am going to run in series with the existing upgrade SC. Last dyno number were about what I called. 530whp, 599wtq.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
