Oil in surge tank, should I be concerned?
Should I be concerned?
Would an oil catch can fix this?
Thanks.
I've seen surge tanks that run catch system have almost no oil build up on the inside. Where as most of the stock ones I've seen, including my own have some form of build up inside them.
spray it would with some brake parts cleaner and that should clean them up nicely.
When I removed them, there was enough oil to wet my finger tip hung up on the ledge of the coupling and the edge of the surge tank tube..
Consistent on both sides.
