Issues while racing a 335i...
You could have a bad pump also and the tires rubbing is because the car lowers at around 80mph
We all die this time of year. You learn to live for cooler weather and do the best ya can.
But I gotta ask...
20's weigh considerably more = slower acceleration
20's rub and burn tire rubber off the tires = slower acceleration & accelerated tire wear.
Are they really worth it?
To the OP I had 20's before also and it was noticeable power loss cauz I bought some heavy wheels at the time. Definetly check the PUMP that was killing me. I never knew wat the hell the problem was till I became a member and that magic CM30 pump made all my problems go away
Curious if the look is more important than functionality.
Stay with 18's if you're dead set on performance or get some nice 19's if you want a good balance.
So, yes, generally, 20s would not be a good idea for performance, but as stated, the stock 18s are not light.
Rolling diameter is all dependent on the tire chosen. The common 20" upgrade people run are 275/30/20 which is 26.5" in diameter vs 26.3" stock, a difference which can be more than made up depending on tire brand itself as tire makes vary in width, tread depth,etc. A wash.
Even my current 19" wheels are 29lbs lighter(total) vs the stock 18s. On my last car I had 20s which were 19lbs lighter (tire/wheels total) vs the 18s and the car was lighter on it's feet due to this advantage.
Many variables involved. Either way, even if the OP was running 22s, the car would still go when downshifting and what he described is not tire size related. Most likely the pump/heating.
I enjoy the looks of a nice set of wheels, but I'm more interested in "freeing up" performance where I can. Adding increased rotational mass at the ends of the suspension arms doesn't seem like a place to start for handling or acceleration purposes.
+whatever on the I/C pump. Mine went out not too long ago, too.
For example, driving at a consistent speed on the freeway... The car learns your driving style and works with it... Perhaps that's coming into play too? Though, I've never had this problem... I don't drive my car hard by any means at all, I treat her fairly well with most strain from freeway on ramp accelerations or overtaking... Still, with my easy driving style, everytime I floor her or "kickdown" she takes off every single time...
