Lessons Learned -2nd Cat-Res Removal please come inside
Old May 8, 2012 | 08:12 PM
vipermike's Avatar
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
@ KLR CLS. I just noticed you have a ton of great mods and I'm wondering why you're using the PLM shorty headers on your beast? That's like tuning your car with 87 octane. If you were to run real LT's, use your stock resonator and stock muffles you would be able to take full advantage of all your other mods and the sound would be very close to stock until you actually floored it. I have LT's, no cats, no resonator and stock CLS muffles and my car sounds very close to stock until I get aggressive, then all hell breaks lose!!
Old May 8, 2012 | 08:21 PM
BenzoBoi's Avatar
Super Moderator
W221
Bottom line...cats choke the car. I definitely feel a loss throughout the curve after installing cats again. She just doesn't pull as hard as before.
I'm sure there is hp to be found after deleting cats, if you choose to do so...
Old May 8, 2012 | 09:46 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Originally Posted by Toadster
I kept my 2ndary cats (shop wouldn't remove them to be honest) - but removed the resonator - but left it straight pipes (no x-pipe) - it has a nice rumbly growl now, but I may add an x-pipe as it should bring more power
How would adding an x-pipe in place of the resonator add more power?
Old May 8, 2012 | 09:52 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Makes sure you get magnaflow though. Buddy of mine put a crappy one on his E55 and became all rusty. Total eye sore lol. Atleast you will gain your low end torque back and maybe a lil hp
Old May 8, 2012 | 09:54 PM
AKnight55's Avatar
The secondary cats already have a crossover built in, so not sure why you would add an x pipe in place of the resonator
Old May 8, 2012 | 11:43 PM
Toadster's Avatar
2005 E55 AMG
it smooths the exhaust pulses between the banks and creates better scavenging of exhaust airflow
while I haven't seen any conclusive data from the E55s - I found this article a few months back where they tested straight vs H-pipe vs x-pipe and the setup with x-pipe made more power than the other two...
https://mbworld.org/forums/w211-amg/...confusion.html
I'm sure someone has to have tested this on the 55s
Old May 10, 2012 | 12:39 AM
  #32
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
One question: how did you have your "exhaust tips adjusted" because mine are buzzing on the CF rear diffuser and it's driving me nuts. Did they cut and reweld the tips or lower the entire muffler?
Old May 10, 2012 | 12:58 AM
  #33
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
try shimming your muffler mounting points with some washers. It could help.
On another note: A lot of wacky tip action (trying to say that with a straight face) can be caused by using flex joints. So for the guys building an exhaust system for their car, maybe stay away from a flex joint. Over time the flex joints loosen up causing the exhaust to sag. Resulting in the tips deflecting, hitting things, that sort of thing. It's OK to use 1 flex joint, but don't use two. Just thought I'd toss that out there.
Old May 10, 2012 | 01:00 AM
  #34
mrweelr's Avatar
Thanks. Shimming the mufflers might just do the trick. I think I just need to drop the muffs about 1/4"
Old May 10, 2012 | 01:03 AM
  #35
at a 1/4" you may need longer bolts. You are going to want some bite on those threads. last thing you want is to be doing is dragging your rear section down the street.
Old May 10, 2012 | 01:40 AM
  #36
KLR CLS's Avatar
CLS63 PP
I picked up 42 whp headers only no tuning changes, so they worked pretty damn good in my opinion. They never proved to be restriction to me making power, and sounded great.
Old May 10, 2012 | 09:09 AM
  #37
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
[QUOTE=MBH motorsports;4160019]IMO The CLS55 has the meanest sounding muffler out of all the AMG's. In the videos below all cars are fitted with MBH long tube headers, primary cat deletes, resonator deletes. Secondary cats are intact in all 3 cars. The SL55 (mine) and the CLS55 (My brothers) have only headers for mods. This E55 makes 580whp on 100oct. The E55 is noticeable much quieter than both the SL and CLS.
I disagree. Have any of you heard a stock SLK55? They had one at the AMG Challenge a couple of years ago. To me, that was the best sounding stock system. This was right when 63s were coming out.
Old May 11, 2012 | 01:13 PM
  #38
mrweelr's Avatar
I found a local exhaust shop to remove my resonator and secondary cats and I'll be getting this done tomorrow. I also have the Magnaflow x-pipe ready to go in. I have a question about the x-pipe placement. All of the threads I searched through say to place the x-pipe as far forward/closest to engine as possible to reduce drone both other threads said to make sure the x-pipe is placed where the secondary cats were. I'm a bit confused about the x-pipe placement now. Should I place it where the resonator was or farther back where the secondaries are? I definitely want to avoid any drone at cruise, thanks.
Old May 11, 2012 | 01:16 PM
  #39
Place it as close to the engine as possible. In the E55's case that's where the secondary cats are.
Old May 11, 2012 | 01:24 PM
  #40
mrweelr's Avatar
OK. I thought if I was also ditching the resonator the x-pipe could be placed farther forward. I'll have him install it where the secondaries are, thanks.
Old May 11, 2012 | 02:01 PM
  #41
AKnight55's Avatar
Yup in place of the secondaries. I placed a pic of my set up in this thread. Absolutely zero drone.
Old May 11, 2012 | 02:32 PM
  #42
mrweelr's Avatar
Sweet brotha, I can't wait to get this done tomorrow and go hunting with the new nasty growl Can you send or repost the pic of your setup, the link is dead. I want to print it out and take it down to the exhaust shop so he has a reference.
Old May 11, 2012 | 03:46 PM
  #43
AKnight55's Avatar
Old May 11, 2012 | 05:01 PM
  #44
mrweelr's Avatar
That's perfect, thanks!
Old May 11, 2012 | 07:02 PM
  #45
AKnight55's Avatar
No problem. All the shop had was 2.5 inch x pipe, but thats not a huge issue if you run into the same thing.
Old May 12, 2012 | 11:55 PM
  #46
mrweelr's Avatar
Got the exact same setup done today as AKnight55 and I was disappointed as I was expecting more growl. It sounds better but nowhere near what I was expecting chopping off that heavy resonator and secondary cats. At least I saved some weight and it sounds a little meaner...will have to look into different mufflers next.
Old May 14, 2012 | 08:53 PM
  #47
AKnight55's Avatar
I was a little disappointing as well, but it is definitely louder than stock.. Can really notice it above 2,000 rpm.. Let someone take your car for a spin and listen from outside the car, I think you will be presently surprised..
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
