What is happening when the new 5.5TT shifts? *vid*
2003 E55 & 2014 GL550
BELIEVE ME, not complaining with our current slushy machines.
Just that I have now seen 2 videos of the new TT AMG working out and when it is shifting through the gears it makes this violent outburst of exhaust during gear shifts. Is it the wastegate opening slightly and blasting through the exhaust?
So much to learn on turbos!! I have been a SC guy for so many years now.
Thanks for any input and just listen to those lightning shifts.
First vid.....listen after 43 secs as he is pulling away. Also listen at 56 secs, sounds like an exhaust leak or something. Weird
2nd vid......watch the E pull away after 30 secs.
hard to tell but to me it just sounds like the engine pitch is changing faster than we're used to because our trannys shift so slow compared to these.
...but i'm just listening to aux speakers attatched to my computer where i'm sure you're professionally disecting each sound bite!!!
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Thats the CLS 63 AMG with a 55 engine..........
Why is MB/AMG marketing not changing the numeric designation to 55TT or TT55?
63 engine is on the way out.
And oh ya, waste gates and or some fancy electronic boost controller.
I'm not excited. I own an SC car (E55) and a TT car (996TT) and I prefer the SC by a HUGE margin. Smoother, better low-end torque, just better all around.
96 and 08 911 turbos
wastegates open at the point when the prescribed boost level (be it by ebc or ecu) is hit. This occurs when you're on the gas.
You're thinking of the bypass/blow off valve, which releases or bypasses the air that has hit the now-closed throttle body and is on its way back to the turbo in an attempt to prevent compressor stall.
not really.
Received 1,069 Likes
E55, GLS450, GL63, GLE350
not really.
The shock can be so severe that it will stop the turbo blades from spinning and can even make them spin in reverse. The damage it can do to the engine and turbo/supercharger is no joke. An engine also runs much better when the turbo/supercharger can spin freely so it can run like a normally aspirated engine under vacuum conditions.
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
http://www.youtube.com/watch?v=wp09o...eature=related
with the amg pack The new tt motor makes over 800nm from around 2000rpm and 900nm from 2500rpm to 3750rpm so i think this motor will have alot more low end torque and power. it will make the 996 engine and e55 engine feel laggy lol
E55 AMG
