Mystery Airmatic Warning - Opinions Welcome
I used to see the malfunction after a few mins of starting the car, and once I restart the car the malfunction will not be shown again during the whole drip. I think it is becus the system is not getting enough pressure at the first start, at the second time the system has more pressure then the first time so it could reach to 14 bar within the required time thus no malfunction shown, does it make sense? And so very possible that the pump is going south without leaking? Any idea?
That's pretty much what mine was doing. It would go up to 10 bar or whatever it was fairly quickly and then just sit there while the pump ran because the leak was bleeding off pressure too fast. If the pressure is coming up very slowly it could be the pump, but I would bet on a leak at one of the fittings. That junction block above the rear axle(and the one in the inner fenderwell in front of the driver side tire) would be a good place to start looking. If you want a good cheap pump I still have the one that I ordered when I was having issues that I'll sell for $100. As far as I know, once the warning has come on for each trip, it will not come on again no matter how long you drive.
I was on the way home and the "Visit workshop" message popup again and I found the front left is slammed but still drivable, so I managed to drive it home and try to rise it and it didn't work. Also, I always feel the car is not level and the message popping up one to two times a week, I have all four suspensions changed not long ago, will that be the valve unit at the link below that is leaking? It is just so annoying...
http://www.germanautoparts.com/Merce.../4032/52373222
is this the sensor you guys are talking about
http://www.partsgeek.com/gbproducts/...nsor+2004+2005
I am a new member here and i have been reading your great comments.
I have a 2010 S350 with air suspension and i have problems with my rear suspensions where they fill up and rise but within 2 minutes they go all the way down..lower than normal and initial review doesnt show any leakages.
I doubt if it is air suspensions that need replacing though because i doubt both rear ones could get messed up at once. Any ideas what to do guys?
You might want to try that.
Good luck, and let me know if this works.
