Suspenison Module location
Old Jul 25, 2010 | 05:14 PM
fastcars011's Avatar
s500 2002
Hello, I have a 2004 E55 AMG. The other day I took it to the dealership because I kept getting an error code every once in a while in reference to my suspenison. He told me that I had a Brabus lowering device and believed that was the cause. I purchase the car used and was not aware. Can someone help me on its location. I would think it would be by the suspenison module, but I can't seem to find that either. Like looking for a needle in a hay stack. Any help would be greatly appreicated. Thanks.
Old Jul 25, 2010 | 07:00 PM
harjothundal's Avatar
05 e55
If I remember correctly, it is by on the front passenger side firewall... You remove the carpet and there will be a panel that folds down with various modules mounted to it...
Old Jul 25, 2010 | 08:21 PM
novae500's Avatar
W211
Yes. pull the ps mat, pull the padded foam and there will be a panel. Once you open it up, you will see the module. I'd set it back to normal and see if you still get the error icon. If so, then some part of the airmatic system is going bad.
Old Jul 25, 2010 | 09:14 PM
Sathinas's Avatar
S65
Attached Thumbnails Suspenison Module location-screen-shot-2010-07-25-7.12.52-.jpg   Suspenison Module location-screen-shot-2010-07-25-7.13.05-.jpg
Old Aug 30, 2010 | 10:50 AM
s500 2002
Big Thanks
Just wanted to drop a line to say "thanks" to all. I found it and took in out. Stop giving me the "go to shop" thing. Is that normal for the Brabus lowering module to produce that code?
