quick question about installing CAMS
C218 CLS63TT PP Edition1, W213 E63S
guys,
does the S/C need to be removed to install the CAMS ??
im thinking on going for Kleemann.
what do u think ?
what do u think ?
No
I got em and very happy... makes the top end really pull and no losses elsewhere ... there is a dyno i posted on it a while back and it shows gains from mid all the way up.
Its actually an easier install than a TB, but might take longer is you know what I mean.
Former Vendor of MBWorld
Whatever we're tuning!
Ali-
What about going with the Schrick cams? A little better/aggressive cam profile than the Kleemann's IMO.
Here are the Schrick cams with the titanium retainers that I recommend doing when installing either set of cams!
http://cid-8b4f5128fba1290b.photos.l...s/P7160775.JPG
http://cid-8b4f5128fba1290b.photos.l...s/P7160759.JPG
The exhaust retainers are a little tricky but I have a little trick to make the retainer replacement much easier.
The titanium retainers are much stronger and much lighter! Since you are already in there it should be a no brainer.
2003 E55 & 2014 GL550
Only thing my tech said was to make sure she goes in EXACTLY like she comes out. One tooth off and she'll run like garbage.
Wonder Benz gives very little info on specs of course so be careful.
Ali-
The titanium retainers are much stronger and much lighter! Since you are already in there it should be a no brainer.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
'13 GT-R AMS Alpha 9+, CLA45, E55
Bruce, have you had problems with the kleemann cams or you just prefer the schrick cams instead? Thanks for the input
if i was in US then sure i would replace other things you mentioned Bruce, but i don't know if the guys here can do it 100% for the springs and exhuast valve, i really don't want to mess my engine thats why i was wondering if i will need to remove the S/C, also some guys here installed Shreck, but they are saying that there are no gains !!!!!!!!!
![Sadwavey](https://mbworld.org/forums/images/smilies/sadwavey.gif)
Might even have pictures since I know where the car is right now!
Talk is cheap.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
Super Moderator
Dayam...yall makin me think about cams now...![Nonono](https://mbworld.org/forums/images/smilies/nonono2.gif)
So Bruce, you have Schrick make cams specific to your specs? These are also different then the ones Schrick normally sells for us? Just want to clarify.
Y'all should get PTE involved in this conversation...I have the PTE/VRP cams in the Beast and he is intimately aware of the install and performance gains of aftermarket cams.
My Beast runs much stronger with the cams in the mid to high RPM range...Jakpro can also attest to this...![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
TTMoto we have a complaint from another sponsor about your claims regarding competitors products. I have referred this to the site owners.
Until they contact you, please restrain from all comments about products that are not yours.
Thread closed.
Thread closed.
