SpeedShift Plus...in a 211 E63?
'15 E63S wagon
So the '07-'09 W211 E63's have standard SpeedShift transmission programming. No throttle blips on downshifts.
And yet the '09 CLS63 *has* SpeedShift PLUS, with throttle blipping on downshifts, like the C63.
My question: because the CLS63 and E63 are essentially the same vehicle with the same engine, transmission and power train...THEORETICALLY could I purchase and install an '09 CLS63 ECU unit and install it in an '09 E63 without any reprogramming required to get the SpeedShift PLUS programming into the E? Taking a wild guess here, wouldn't the programming be the same for both vehicles, minus the trans programming?
Wouldn't the unit drop right in? Or do the ECUs have a proprietary/car-specific coding that would prevent this? Maybe I'm way off...or maybe this would work?
Someone edu-ma-cate me here.
1 Post
2007 E63, 2005 Dodge Ram Hemi
ECU's are VIN coded, but they VIN code them at the dealer (they're generic, but won't work until you assign them)...Though I have no idea, I always wondered why you couldn't get that TCU code in the E....
E63, S550
I've read on the AMG private lounge that it's not possible even though the very similar CL63 and C63 have it because AMG would have to write new software for the E63 and re-certify it. AMG did not see it as being cost-effective. A couple SAs confirmed this too.
I posted a thread about this a year ago.
'15 E63S wagon
V12-Biturbo
You don't understand, they're Vin - coded meaning ECU will ONLY will work on the car w/MATCHING VIN # Your MB dealer can't/wont do this PERIOD. They wont even sell you an ECU from another model w/OUT matching Vin #'s
'15 E63S wagon
Ok if they're VIN coded then that solves the issue...can't do it. That's the part I was unsure of.
BTW not confusing the CL with the CLS at all. The '09 CLS 4-door has the Speedshift Plus rev-matching downshift/throttle blip programming. Considering the CLS and E-Class are essentially the same car w/the same engine & transmission, it seemed like it could be possible to swap out ECUs.
Too bad MBZ won't do this. Doesn't seem like any re-programming necessary.
E63, S550
Knowing the new E63 would have the MCT they figured spending the money to change the programming on the last model year of the 211 AMG was not worth it.
I suppose you can be the guinea pig and get the computers from the CLS with the VIN and try it on your E
W211 E63
This is exactly why I also think a 09 CLS 3 Spoke Steering wheel will fit on the W211 E63 as well.
E63, S550
I just sounds superb to hear the throttle blip on downshift I don't think it makes the car faster down the 1/4 mile. It may help on a road course but I'm not sure about that.
the vin coding screws everything up.
Im sure it is possible but you would need to be able to hack the code to get the car to start and not reject the foreign ECU
So in laymans terms: Whan you hit the down shift button, or when it does it on its own, you will hear the engine rev about 500 RPM over where it was when the downshift was initiated. Thats about as good as I can explain.. keeps the car from actually slowing on downshift abrubtly
