Throttle body help please!
Old Aug 4, 2010 | 12:39 AM
Infiniti's Avatar
a unicorn tuned p30 e63
Hello all,
I was chagning out my valve cover gaskets today and seen the dirt that was on in the trottle body, i happend to have some throttle body cleaner so i sprayed some on a rag and pushed on the plate for the throttle to open so i can clean it and now the car is idling higher than normal and the throttle gets stuck and have a check engine light, any suggestions?
Thanks in advance
Old Aug 4, 2010 | 03:38 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
make sure you did not push out the black tube at the bottom of the TB -- breather hose -- Sounds like you have a leak somewhere -- that could be it.
Old Aug 4, 2010 | 03:39 AM
did you remove the TB ??? when you were cleaning it
Old Aug 4, 2010 | 04:16 AM
Infiniti's Avatar
yeah that was the issue,its the little aluminum line that is used as a bolt on the valve cover that needs to pe pushed into a T fitting so there is no leak. after i posted this i kept seaching and found a thread all about it, thanks man.
Old Aug 4, 2010 | 04:31 AM
£ C43 £ AMG £'s Avatar
E55K AMG
+1
I doubt very much that you damaged the TB just by doing what you describe. I have opened mine up a fews times and the electronic board and motor with no problems.
Classic mistake which I made and had me going nuts for a while and engine was doing all sorts of things including running rough once warmed up, you wont see the vaccum pipe unless you use a mirror. I did not know it was even there at the back of the engine. Thanks to the guys on this forum
Its near the TB but its not the one attached to the TB, just near it on the drivers side if you are left hand drive. Just spray cleaner around the TB for a while until engine rpms change.
https://mbworld.org/forums/w211-amg/...tationary.html
