Motive Power Brake Bleeders now in stock
Old Aug 6, 2010 | 01:34 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
We just got our order of power bleeders in stock from Motive. If you do your own brake bleeding in your E than this will make the job easy for you. I was amazed how filthy the brake fluid get's on these cars. Whether you are adding our stainless steel brakes lines or you just want to renew your fluid, this brake bleeder will make the job easy for you.
Motive Power Bleeder- $50.00
Fluid- $15/liter
Stainless Steel brake lines- $150.00/set of four
Project Mu brake pads (coming soon)-
-Front- $375.00
-Rear- $200.00
We have the fluid, stainless steel lines and Motive Bleeders in stock and ready to ship.
Old Aug 6, 2010 | 01:38 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
can the power bleeder be used on the SBC system?
Old Aug 6, 2010 | 02:12 PM
Staff@RPM's Avatar
Yes
Old Aug 6, 2010 | 03:53 PM
komp55's Avatar
ML550
Yes, I used a Motive Bleeder when I installed my Brembo GT kits. The thing to remember is that if you bleed without using SDS, you're only getting a partial bleed since you're not activating the various valves in the SBC control unit. Even so, I was very pleased with the results obtained using the Motive bleeder. Definite thumbs up on that product.
And don't forget to use DOT 4 Plus brake fluid - your SBC's life depends on it.
Old Aug 6, 2010 | 03:58 PM
Staff@RPM's Avatar
If you would like I can send you instructions on how to bleed the car without the Star and still activate all the valves in the SBC system. I have the instructions from alldata, it's a very silly procedure. If you have a fax number I can fax it to you. I will also send the instructions out with the bleeder if you let me know that you need them.
-craig
Old May 30, 2012 | 10:25 PM
GRAFH's Avatar
2005 E55 AMG
What's the part # for the one you sell?
