Brake Problems?!?
Old Aug 18, 2010 | 04:04 PM
NSX2NV's Avatar
03' E55 Techtite Grey
Brake Problems?!?
Hi Guys,
About a couple weeks ago my display started showing "Brake; Service Brake; Visit Workshop" After that started happening my keyless go isn't starting on the first time because it thinks my brake isn't pressed so I have to pump it a few times before it will pick it up. Also I noticed a low pitched squeak right after I press it while driving . I checked the fluid and it is at the full level. Has anyone ever come across this problem? Is it something I can fix myself or do I have to take it into the shop? I just replaced the pads and rotors about a year ago.
Thanks!
Old Aug 18, 2010 | 04:39 PM
grantwoodtx's Avatar
GLE 63S
I had a similar issue and the accumulator reservoir which is part of the SBC system had to be replaced. This is NOT covered under the SBC warranty.
Old Aug 18, 2010 | 06:46 PM
NSX2NV's Avatar
Oh no how much did it end up costing you?
