Going to have the ASP 180MM Pulley Installed Next Week - 1 Question
I'm taking it to a professional MB specialist, DynoComp in Scottsdale AZ but is their anything specifically I should tell them to install it correctly?
Here's what I've been told:
"The ASP 180mm pulley is an overdrive pulley not an underdrive. Also it is imperative that it is installed properly. 148tft/lbs and then a 90 deg stretch."
Sorry if this is a silly question, just want to avoid any of the dreaded, "Pulley wobble" due to improper installation.
Thanks.
Alex
Thanks.
Alex
Former Vendor of MBWorld
Like torquing it to a specific pound, etc?
Thanks.
Alex
Thanks.
Alex
Did the pulley come with a crank bolt? You going to want a new one.. If not just let me know, I'm going to the dealer today I can pick one up.
No it did not so thanks very much for the offer! I'm also going to have you install a larger Heat Exhanger as well at the same time. Just curious what is the cost of the bolt?
Again thanks very much for doing this!
One other question for you, the pulley came with a new belt, but I'd also like you to replace the, "Other" belt as their are two. Very sorry if this isn't specific, but since you're in there I figured do both.
Do you have that belt as well or could you get it from the dealer?
Looking to install all of this with you next week.
Thanks again, really appreciate your help here.
Alex
Alex
Alex
Alex
What H/E are you using? If you haven't got one yet.. I could just make you one. No biggie, just letting you know the scope of what we can do.
You're car will be in good hands. Matt and Matt, the two main techs, know their stuff and are very good at what they do.
If you have anything custom you want or need done, feel free to ask. We can do just about anything this side of installing a solid rocket booster.
Whatever we're tuning!
I'm not sure what the bolt cost, but I would think its like $10 or something. If its more than that, I'd say I would be shocked, but it is the dealer so... I'll check for you. No problem on the belt too, I can get it from the dealer, but there are other options locally that have the correct belt.
Yes thank you both including the quote! I've gone with the Heat Exchanger from Jerry at EuroTek, so it's a once piece, larger unit. It should, "Bolt right in" and yes if you could pick up both the bolt and belt I'd greatly apprciate it.
I'll give you a call in the next day or so to make the actual installation appointment. Thanks Mike you guys are fantastic. (You installed the Johnson pump for me on the E55 about 6 months ago so you get all my service going foward.)
With the 180mm on and H/E, I'm looking at the Quaife LSD through TTMotorsports for my next mod. From there all that's really left is headers.
This is why I love this place so thank you three, TTMotorsports, Eurocharged and Dyno Comp!
Here's the I purchased: http://www.eurocharged.com/index.php...mart&Itemid=99
Alex
Alex
This is why I love this place so thank you both, TTMotorsports and Dyno Comp!
Alex
Alex
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Mike the bolt should be $20 bucks, looks like things are continuing to go well over there... I'll come and visit rich, ken and you once the heats drops down.
2003 E55 AMG
It's you...what ghettotastic part of Phoenix do you live in?
Will do Mike33! Yeah I live in Queen Creek (Pinal County) but I'm actually in NY for the week at the moment for work, so I'll check with the wifey as to how the house is doing.
We got walloped Saturday night with a Monsoon but the AC's do still seem to be working OK.
ETA for the 180mm and HE install is mid next week via DynoComp.
Thanks again everyone!
Alex
Alex
2003 W211 E55, 2003 W220 S600
200nm plus 90 degree turn
these are the torquing specs for a larger crank pulley / harmonic balancer that is made from a OEM MERCEDES pulley / harmonic balancer.
PLATINUM SPONSOR
Stock AMG crank bolt runs about $28.00 each.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
