First time at the track!
Old Sep 19, 2010 | 03:37 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by mikey33
BTW, my car put down 420whp and 480wtq at dyno-comp, so I think my car should be a lot stronger since it has some of the highest stock #'s that I have seen people post on here.
those numbers are right on par for as stock 55 with dynocomps new dyno settings.
at firebird i used to run consistent 1.71 60ft times on 19" toyo street tires so you should definitely be able to get your 60ft times under 2 seconds, which would put your et's where they should be...in the mid 12's.
Old Sep 19, 2010 | 04:50 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Originally Posted by guysandiego
last time i was in LA -- my car was a beast compared to Vegas -- Doing a 1/4 in vegas is probably a huge handicap. We have the HEAT... elevation of +3000ft and 91 octane.
I have seen it posted many times but i dont understand how to get the DA -- and I dont know what is good-average-horrible. Is there a link to explain?
If you can run in anything between +400 to -400 is ideal, but remember sometimes a DA any lower than -400 is not always a good thing. The closer you get to 0 is better.
Old Sep 19, 2010 | 04:52 PM
FLSL55's Avatar
SL65
You need to replace your IC pump.
Old Sep 19, 2010 | 05:40 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
So, DA = elevation ??? Basically Vegas is a horrible place to see the car's potential -- It could be worst.. I could race a 1/4 uphill.
Old Sep 19, 2010 | 05:57 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
Dragtimes, they have a calculator and an explanation...really good DA is negative, but anything near 0 is money....
Old Sep 19, 2010 | 06:42 PM
Density altitude...it's a combo of everything...obviously being at elevation is already a handicap, but temp and humidity are factors too...
Old Sep 20, 2010 | 12:03 AM
  #32
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Thanks for all the input guys! Thing I noticed was that all my back bumpers and the rear tire well liners were chewed up and the burnt rubber was plastered all over the bumpers and exhaust pipes. The crap does not come off easy so I had to use a brillo pad, hopefully I did not scratch the paint. I think I need to get smaller wheels and tires for the rear before going again.
Old Sep 20, 2010 | 12:13 AM
  #33
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
Use either painters tape to tape the area or go to a car wash immediately after with the manual "high power spray" and power wash it off. . . I had the same problem and Clayton recommended that to me - we're both pretty OCD when it comes to what touches our paint so I immediately trusted his suggestion. . .
Old Sep 20, 2010 | 02:02 AM
  #34
mikey33's Avatar
Hey, great idea motorkas! It looks like I have good clearance between the side plastic in the wheel wells, so I am not sure how it is burning up and melting??? Plus, if it is rubbing a lot like I am guessing that might be slowing me down lol. What do you guys think about it slowing me down?
Old Sep 20, 2010 | 02:16 AM
  #35
rubbing = slowing you down ... your thinking too much
