air conditioner to cool down IAT...is it possible?
#76
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I have a couple of questions: (1) On a long (let's say 25 seconds) WOT pull will the IAT remain substantially lower? In other words, is there sufficient BTU capacity to maintain lower IAT for more than a few seconds? (2) What is the recovery time after a WOT pull? I would assume most of you don't need reduced IAT for more than 12 seconds.
The KC videos are impressive, however the pulls are for only a few seconds, so we don't know what the IAT's would be beyond that.
This is one thing that would be the first consideration in the design phase.
I think that this mod is being misrepresented here, and you are on the right track questioning the BTUs.
We all know how long it takes for the AC to cool off the car in the summer heat, and the interior volume is what 120 cu feet. Now our kompressor moves a volume of at least 600 cubic feet of air (@130+degrees) in one minute @4800 RPM.
So lets have KC post up how this actually works and for how long.
I think we will find it is short lived and may take a long time to recover, perfect for 1/4 drags but I don't see how this could be used for any sustained period of time.
BTW Yes our AC compressor is on all the time, but it is variable displacement so the load or parasitic drag is variable as well.
#77
AgSilver I have not seen one creditable Super Heat calculation for this mod.
#79
Testing is one thing, the theory needs to be on paper first. I don't see how an AC system that has maybe 5000 BTUs can sustain cooling the charge air.
I just want you guys to think this through, ask questions, first of which should be, show me the superheat calculations.
So before everybody buys it, I think we need to know exactly how much heat it can pull out of our intake charge and for how long.
#80
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
well this killerchiller maybe good for a short busts of WOT, as Bassn07 said he has seen the system work.
Yatch Master is also correct by asking as to how long can this system sustain cooling the fluid in the heat exchanger.
We have to remember, mod your car so it will suit your purpose. for the 1/4 mile guys this system maybe a break through in controling IATs for the circuit/track guys this system may be less effective.
this is just my 2 cents, before people start bashing each other.
#81
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
![](https://mbworld.org/forums/attachments/w211-amg/193216d1286224939-air-conditioner-cool-down-iat-possible-copy-p9290072a1.jpg)
#83
Myself, I live for the 1/4 mile and love doing it. All of my testing has been done at the drag strip and always will be. I have no intentions on testing a product that doesn't fit my needs, I'll let that group of people do that themselves.
I would have to believe that this system would help regardless of the application. Obviously it will have the most benefits on the drag strip or short bursts out on the streets. Even in the 1 mile events starting at 30-40 below ambient will definitely have it's benefits over starting at 20 above. Will that reduction in IAT's be linear over the course of the mile, I have no idea. My guess would be probably not but you will gain the advantages of cooler IAT's up to a certain speed. I've seen two very similar modded E55's run at the drag strip and one without the KC finish at 170+ degrees and the one with finish at 130 degrees. I was sold on the system after I watched Scott hot lap his car with very consistent times.
Course racing is a whole different ball game and I have no idea what the gains would be if any. In theory it should help but until someone is willing to test it, a theory it will remain.
Just keep in mind that Scott isn't here trying to make a quick dollar but instead trying to help the community with a product he's testing. When I say testing, it's on his 06 E55, his own dollar, and his spare time after work. He's just an enthusiast trying to help resolve an issue that has plagued our platform for the past 7 years.
I have really don't have anything else more to add and my next post on this subject will be after testing. You guys could theorize all day long, I'll be getting some live data at the track...good luck!
#84
A better choice would have been, we are hearing the good part, and we like it, Now what don't we know about it? Apologies to Bassn
#86
I really don't have all the answers and can't accurately answer some of the questions asked. All though I do know that every concern I had has been satisfied to the fullest. These kits have been around for a while and there a ton of other cars running them with no problems. Is there anything that makes our cars that much more unique over them?
The same thing happened about methanol, since no one has really done it successfully on our cars people thought they were a big no no. Along comes Sneakyneon, a old school racer that applies the same thoughts to our MB's as he did with other boosted cars and successfully gets it working. Now we have plenty of people on the boards wanting/already completed the meth install.
Change is good and I'm glad we have plenty of people on the boards willing to explore. I'm willing to test and prove out his setup on my car and I promise to report back with my findings.
Stay tuned!
#87
E55, Supercharged Z4 (sold)
Wouldn't it be neat to have a valve that could change the flow of fluid from the IC->H/E->KC direction of flow to IC->KC thereby passing the H/E? Either by a hard wired switch inside the cabin or a thermostat?
Even cooler would be a logic filled switch that would direct fluid to the H/E until the fluid got to ambient tempature and then directed it solely to the KC until the fluid temps rose again.
Makes sense in my head anyway.
#88
To me this kit could best be used to cool down the rear tank reservoir... particularly when you are waiting... it just runs full time cooling down the reservoir tank. This can then circulate and cool down the s/c too... while you wait - or off boost.
Thats what I am after ... a system I can switch on to cool down my tank with having to chuck ice in and drain out hot coolant.
Not sure having this feed the I/C directly is the best way apply this unit.... lets see whet the testing brings.
#89
#92
1 Post
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
They don't have a kit,yet,they have the parts list of what they supplied me w/ no install instructions.After my next install i'll have solid pricing/parts/general install/pictures list,hopefully in the next week.also I ran the race kit,where you turn off your interior cooling effect and everything is concentrated on the kc core resulting in even lower iat's.I've had some issue w/ this setup,if this valve fails you will get no in cab a/c,the valve they use is normally closed.all the iat #'s I have achieved have been w/o a split reservoir and no race valve setup.
#93
#95
#98
ha ha You would think so but with what he's said about his IAT's using water/meth injection and his intention to use this killerchiller (which I think sounds awesome) I was surprised to read this. I know Alan doesn't just do something for the heck of it.
#99
1 Post
2008 ML63 2009 SL63 2010 Alpha 7 GTR
This is true, I have heard about some people not liking the "jerky-ness" of a larger pulley...But that would be a drive-ability thing, not a 10 sec pass thing, which is what ol' Alan is up to...
#100
S/C parasytic losses and efficiency starts going haywire when you spin these things too fast....
