Bogged down after a couple redlines
Old Oct 9, 2010 | 12:43 PM
Jasoneo5's Avatar
W211 E55
Hey all,
After a couple redlines my 03 e55 seems to go into some type of safety mode where I loose most of my power completely. Usually comes back after a few minutes?
Intercooler pump?
Jason
Old Oct 9, 2010 | 12:57 PM
juicee63's Avatar
2011 twin turboed prius
Originally Posted by Jasoneo5
Hey all,
Intercooler pump?
Jason
Your car is going into limp mode. Most likely a pump, your too hot. If your pump is bad you will lose power after a few attempts at WOT
Old Oct 9, 2010 | 01:02 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
CM30 time!
Old Oct 9, 2010 | 02:56 PM
sneakyneon's Avatar
Bicycle
Hey all,
Intercooler pump?
Jason
More than likly your IC pump,
How do you plan on using the car? Just a daily driver with a once in awile blast or going to go to the track or more racing? You may want to consider a pump upgrade and splitting the system, Other wise just replace the pump.
The progression of cooling is like this:
Upgraded pump
+ split the system
+ Heat exchanger
+ rear tank res.(ice as needed)
+ Water/meth injection
Old Oct 9, 2010 | 11:20 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
CM30
http://apeusa.com/html/jabsco.html
Old Oct 10, 2010 | 03:14 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Yup replace that pump and you'll be good to go. I was so happy when i changed mine. No more shutting down after those high speed runs down in Mexico.
Aaron
Old Oct 14, 2010 | 01:42 PM
Jasoneo5's Avatar
W211 E55
How hard is the install? Should I buy special fluids because some might leak when disconnecting the hoses?
Just got the new pump today..
Old Oct 14, 2010 | 02:23 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
install is very easy. there is a write up in the DIY section. You may want to have some coolant on hand.
Old Oct 16, 2010 | 04:19 PM
Jasoneo5's Avatar
W211 E55
Just replaced it, took about a hour and a half. Super easy and I'm no mechanic by a long shot.
Already feeling a pretty big difference through the gears.
One question:
By the electricals, there was a very small hose connected to the stock pump that the CM30 did not have. No fluid came out of it when I disconnected it, so I just left it dangling there and there doesn't seem to be a problem. Anybody know what I'm talking about?
Old Oct 17, 2010 | 12:23 PM
bobhamilton1509's Avatar
2005 E55
Dumb question, why is there a need for an aftermarket pump?
Couldn't you install a new OE pump (especially for CPO cars)?
Old Oct 17, 2010 | 01:48 PM
cal1's Avatar
SL55, ML500 & Acura TL
You can and the newer OE pumps seem to be better as far as failing or reduced flow rates.
The Johnson pump has higher flow rates than the stock pump. As intake air temps (IATs) rise, power drops off so higher IC pump flow rates keep IATs cooler and result in less power loss.
Old Oct 18, 2010 | 10:34 AM
lowprofile's Avatar
E55
^ Higher flow as reported by who, Johnson manufacturing?
I do not recall anyone measuring flow of both pumps while pushing coolant through the i/c or h/e.
There was a short video of someone measuring the time it took for each pump(stock Vs Johnson) to fill a bucket and the results were identical.
I would just replace your pump with the stock pump.
Old Oct 18, 2010 | 10:47 AM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
I replaced the stock pump on my 06 with a cm30 when I first got the car due to all the threads on the forum saying how bad the stock pump was and what an improvement the CM30 was. I noticed no difference at all in the performance of my car with the CM30.
My dealer freaked out on the CM30 pump and, "suggested", I put my old pump back if I wanted to maintain my warranty. So I did, and it promptly quit working. Dealer replaced it with the new style Bosche pump under warranty and it's been working great ever since.
My take after all this is, that if you're going to replace the pump, replace it with the new Bosche and not the CM30. The Bosche was designed for the car and the newer models don't quit. The CM30 works OK but was originally designed as a bait well pump for your fishing boat. It flows a little more than the Bosche but if increased flow is the goal, there are other pumps that flow a lot more than either.
Old Oct 18, 2010 | 11:00 AM
HadiLaw's Avatar
2004 E55
When I first bought my car the pump was already bad. I wasted my time and money on replacing it with the newer OE pump. Once I installed the Meziere, I have never looked back. I heard a lot about the CM30, but I wanted the best quality pump, and the pump that PUMPS the most. haha.
Don't waste your time and money on another OE.
