Drag tire/rim question
Dirt Scooters
I want to get some drag radials but i'd like to get some 17's and put some 275/45/17 drag radials. Does anyone know what size or what oem rim i could get to put these on? I'm not trying to spend a bunch of money on custom rims for it if possible.
I run a 275/40/17 MT ET Street Drag Radial and they are mounted on a 17x8 or 8.5 I forget. I have to go check. Ebay is your friend
Dirt Scooters
What kind of rims are you running? I was thinking about just getting the 265/40/18 for the stock rim but i'd like to have a set to just swap out when im going racing
17" OEM MB wheel, my guess is that the 265/40/18 is a .5 taller tire than the 275/40/17 which may result in slower traps
If you want to mount them on the stock 18's, get the BFG drag radials in a 275-35-18. They are just a sticky if not more than the MT and a smaller profile tire.
the guys on the SVT Forum talked me into running that setup, I think if I drop the psi a couple more pounds it will help me get into the 1.6x's
