E63 without carbon filter throws CEL
Are the missing carbon filters causing the CEL? Are any of you able to run without the carbon intake filters without throwing a CEL? Note I did go with the factory air filters not K&Ns. Do I need to put the carbon filters back?
To this point no CEL car has around 17k miles.
Hope they will still cover you under warranty as you brought it in before expiration.
The first time I brought it in the codes were 0817/0821 [secondary valve jammed open for bank 1 & 2] and 0745 [self adaptation for enriching mixture at idle above permissible limit] and 2091 [mixture right bank too lean when idling]. They replaced a vacuum valve and values tested ok afterward but CEL came back on after 2 days.
I dropped it off again and now they think it is an intake gasket leak just like you mentioned. Not sure what gasket they are referring to- I'll find out
Thanks for all the responses!
I always like to go back to a know condition. Which meas out the charcoal filters back on, reset the CEL and see what happens. I'm certain CEL will come back on.
Good luck!
Anyway, thinking about the codes/descriptions, since the codes indicate being lean at idle it can't be related to the air filter/carbon filter. The throttle plate is almost fully closed at idle with little air flow but high vacuum in the manifold. Any gasket leak would show up at idle. Makes sense.
I'm surprised how well it idled though even with the leak.
They replaced the "resonance intake manifold gasket to the cylinder head" per document 09.20-P-045901 for leaking intake manifold gaskets.
Intake manifold leaks seem relatively common on these cars given that there is a maintenance doc on it.
The CEL was not related to the carbon filter removal.
