Will a W211 Crank pulley fit on my W210?
Old Oct 27, 2010 | 07:50 AM
ABALONE's Avatar
2001: Supercharged E55 AMG
Hi!
I might be looking to drive my S/C with a separate 8-rib belt system like on your W211. That way i can raise the boost and have less belt slip, then just going with a larger crank pulley and run all the accessories and S/C on the same belt = More belt slip.
But i wonder if the bolt pattern on the W211 crank pulley is the same as on my W210? Should be right?
Thanks // Magnus
Old Oct 27, 2010 | 09:12 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Originally Posted by ABALONE
Hi!
Thanks // Magnus
Ted Baldwin changed to a 8 rib system on his W210 E55K, You might want to read his tread. Good luck Magnus!
https://mbworld.org/forums/w210-amg/...ou-please.html
Old Oct 27, 2010 | 11:53 AM
ABALONE's Avatar
Thanks Peter, i've seen that one earlier. But i'm looking to run my S/C with a separate 8-rib system like the W211 E55 and let the inner belt run all the other accessories just like now.
Ted did a swap to just a larger crank pulley (C32 i guess) and overdrove the accessories with one belt.
