On dash voltage display
Old Oct 31, 2010 | 02:20 PM
edmond1129's Avatar
E55
I recently have the "Battery Protection" message and I searched around the net and I found that we can have the voltage showed on the dash. I dont know if it has been posted before but I just want to share what I have found and if possible, tell me the voltage you are getting from the display, therefore I know if it is my alternator going bad, thanks guys.
1. Turn your key to position 1
2. Briefly press the "R" button 3 times
3. You should have the current voltage shown
It will show as an extra manual and you can start your car with it and keep reading the voltage. It will gone if you turn off the car and the next time you want to see the voltage, just to the steps again. The extra manual also showing the engine oil level when engine on as well as the VIN.
Key in Position 1
Idle
Attached Thumbnails On dash voltage display-img_0271s.jpg   On dash voltage display-img_0272s.jpg   On dash voltage display-img_0273s.jpg
Old Oct 31, 2010 | 09:11 PM
izzyz28's Avatar
2004 E55 AMG
Depending on the ambient temperature, I typically see 11.9-12.2 volts before startup with key in #2 position, 10.1-10.5 volts while its cranking, and right at 13.9 while the engine is running. I've also found that the voltage displayed is typically .2 volts lower than the actual voltage measured at the battery for whatever reason.
Old Nov 1, 2010 | 01:09 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
this is the dynomode menu
you can see engine oil level, chasis number, turn off ESP. reset service, etc
Old Nov 1, 2010 | 01:27 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
...and you can also monitor the voltage via the heat/ac control.
Old Nov 1, 2010 | 02:55 AM
Ali_E55's Avatar
i cant, not matter which method i use, that hidden menu does not pop.
Old Nov 2, 2010 | 08:22 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
^^Ali is your car an 06? Mine is and I discovered the button to do the trick on my 06 is to hold the driver side auto button for a while (5 or more seconds i can't recall).
Old Nov 3, 2010 | 01:55 AM
Ali_E55's Avatar
mine is 2005, i tried every way mentioned in the forums but nothing, i noticed also all my friends who has 2005 also cant see it.
one my friends has 2006 and it shows by AUTO button.
Old Feb 1, 2011 | 08:14 AM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Trying to access the Service menu to reset the service indicator but having hard time getting Voltage displayed in the instrument cluster ? Any ideas as to how to get Voltage displayed. It's an '06
Old Feb 1, 2011 | 08:37 AM
GT-ER's Avatar
2005 E55 AMG
Interesting...I have an 05 and it works great. It must be in the MPH/TEMP display for it to work though.
Old Feb 1, 2011 | 09:01 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This method works on my 07 E63, it is the same process used to reset your oil service (FSS Reset)
Old May 5, 2024 | 09:13 PM
Mohammed_ksa's Avatar
MB 2007 E350
I'm having the same thing but my car, won’t start!
