Custom Intake
It came on last night and it was about 29-30 out
Tonight was 45 and it never went over 187 with hard driving and was around 180-83 normal driving.
We can compare intake temps too since we're local
full 3" teflon coated tubing to a 3" silicone y splitter at the t/b. high flow k&n filters up front. the drivers side has a 2.75 " reducer to allow passage thru the rad support without cutting anything.
heres some flow data from rob to show the increase.
stock slk32 intake = 446cfm
sl55 intake = 514
sl55 with devil horns = 531
single CAI with teflon = 602
dual CAI with teflon and big filters = 748
this setup shows a 20 rwhp inc in the s/c 3.2 engine in my 32
Last edited by 320 dreamer; Dec 25, 2010 at 12:24 PM. Reason: editied the srt-6 to slk32. same intake
so basically adding the filters up front and hooking them up to the python tubes.
if your set on keeping the oem setup call rob for his "devil horns" they will help direct more air to the boxes.
you can see form the flow # the oem flows substantially less than the dual cai
sl55 intake = 514
http://www.crossfireforum.org/forum/...ch-tested.html
skratch i understand the concept of the renntech tubes and boxes. i tried sl55 setups slk32 modded airboxes with stainless tubing and devil horns homeade tube sets like the dual cai but all had so much turbulence you lose airflow. regardless of the renntech top the air still has a 90* direction to go and pass thru filters in the middle of the stream creating turbulence. i wanted more than anything to keep my center logo and the airboxes but flow # dont lie!
sl55 intake = 514
You have to appreciate the actual testing that was done and the results speak for themselves!
I am sure a filter change will make even more of a difference. Either the XStream K&N's or the Weapon R SW velocity filters would do the trick!
the filters on mine were dirty b ut cleaned and oiled now. the problem with using bigger filters is fitting them behind the grill. i actually had to have a custom grill built to house everything in front. not cheap!
i do have the xstream k&n's for the track. remove the grill and let em flow!!
Stock SRT-6s have gained as much as .5 seconds in the 1/4 from just the NW dual intake alone, no tune.
