Please help - my new 20" wheels do not fit
E55
Just installed the 20" HRE that I purchased from another member (Thanks! for the deal). The rear wheels fit fine but the front ones do not fix. There is a bolt from the suspension that is rubbing the tires. For the front tire, I have the same tire setup as the previous owner (245/35/20). Is there something I am missing with the setup? The tire guy wanted to shave the bolt but I dont want him to do anything stupid. Right now I have the HRE for the rear and stock on front. It looks wierd.
'08 G55 AMG
I think the bolt you're mentioning is the upper control arm bolt that sits just above the tire then the wheel is mounted.
When I had 20s on, I did notice the clearance up there between the top of the tire tread and the bottom of the bolt is VERY minimal, a few millimeters at best.
I was running 245/30zr-20 and it just fit, but I can imagine how running 245/35 zr-20 would not work given the larger outside diameter.
I bet downsizing to a 30 aspect ratio would solve the problem. Just watch out for the potholes!!!
Super Moderator
Are you talkin about the bolt that goes straight down from top to bottom? I think it's your tire size. The tire is too tall if I'm not mistaken. I ran into the same problem 7 years ago when I picked up my car and tried to slap 20's on it. The tires were too tall and therefore rubbed into a bolt at the top of the suspension. Found out right when I tired to put on my 20's right before the show.
^ Correct
The proper tire size for 20" is
245/30-20
2X5/25-20 (Can run 275 or 285)
Running the taller tires can help save the wheels from potholes, but other issues arise.
245/30-20
E55
Thanks for all the fast advise. Going to find some other tires. I wonder how the 245/35/20 and 275/30/20 setup worked for the other E55s? I am glad I did not have them shave that bolt. Should I also replace the 275/30/20 in the back?
Check this out
http://www.rimsntires.com/rt_specs.jsp
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
They work fine for me because I'm guessing my wheel offset is different than yours. However, I hate the lifted look it gives the car. The previous owner put the tires on a month before I bought the car, so I can't justify getting rid of them, therefore I'm just waiting for the to run their course. Maybe a good smoky session will help that along......
