Holiday 10 days sales: W211 E55 W211 E63 Carbon Fiber Front Lip $200 SHIPPED!!!
Old 06-06-2011, 05:49 PM
  #101
1 BAD BURB's Avatar
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
Whomever on this thread, that has bought a lip for their E55/E63 and have GONE faster then 140mph, please pm. i want to know that it has worked! multiple times please, not just one stint and thats it, ever.
1 BAD BURB is offline
Old 06-14-2011, 12:29 AM
  #102
alltrac's Avatar
2004 E55
Need a E63 lip..pm sent..
alltrac is offline
Old 06-14-2011, 12:32 AM
  #103
Gus83's Avatar
2009 E63
i will guarranty that mine will hold over 160, but thats bc of how i do my installs.
i will start a thread after im done with pics and everything and what i used.
PS: i wont be using the sefl tapping screws, ill be fabricating brackets
Gus83 is offline
Old 06-14-2011, 07:49 AM
  #104
1 BAD BURB's Avatar
Yea, fully agree. Now that I look back, there needs to be a lot more support on these lips since they don't round over the front bumper at all.
I followed his "instructions" (or there lack of) and even over did it. Still luck.
I'd also suggest using bolts and nuts. Then they def can not fall off!
Old 06-14-2011, 09:59 AM
  #105
Gus83's Avatar
2009 E63
I will be using nuts and bolts and brackets
Gus83 is offline
Old 06-14-2011, 01:19 PM
  #106
Former Vendor of MBWorld
Suvneer's Avatar
Looking forward to the pictures, Gus.
Suvneer is offline
Old 06-14-2011, 01:49 PM
  #107
alltrac's Avatar
2004 E55
money sent...
alltrac is offline
Old 06-14-2011, 02:16 PM
  #108
Gus83's Avatar
2009 E63
will do gary.
Gus83 is offline
Old 06-15-2011, 11:24 PM
  #109
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
I am interested to see how this goes. Because, quite honestly, I did not really think that much about the higher speed stability until you guys started talking about it. Seeing as how there have been several times where the E63 and I have seen sustained 140 mph + blasts, it now freaks me out to think what would happen if that lip tore off at those speeds. When you guys get yours mounted, please share with the group how it holds up. Thank you.
Meeyatch1 is offline
Old 06-16-2011, 03:38 PM
  #110
Suvneer's Avatar
I wish I still had my old bumper and lip so I could step on the lip and show you guys how hard it holds
Suvneer is offline
Old 06-16-2011, 04:24 PM
  #111
E55Dimon's Avatar
E63S
I've been at 140ish with just 4 bolts. It held up fine. Now I'll be adding some more in though just in case.
E55Dimon is offline
Old 06-16-2011, 10:37 PM
  #112
Meeyatch1's Avatar
Man....you need to take the picture of your car out of your signature. I keep drooling on my lap top and may have short circuited the keys.
Old 06-17-2011, 10:49 AM
  #113
E55Dimon's Avatar
E63S
On a side note, correction: 5 Bolts I have. It may seem like a bad idea to some of you but I feel pretty confident with the install..(have had many aftermarket bumpers/lips on my cars). I will be adding a couple more bolts in there though. You know, just to be sure.
E55Dimon is offline
Old 06-17-2011, 04:57 PM
  #114
Suvneer's Avatar
I agree
Suvneer is offline
Old 07-08-2011, 06:37 PM
  #115
Suvneer's Avatar
Back in stock!
Suvneer is offline
Old 07-08-2011, 06:51 PM
  #116
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
I've done a bunch of 140-155mph pulls with my lip on and haven't had a problem yet. Used the self tappers provided and it hasn't given any problems, aside from a few bugs splattering on my front end. Great product Gary!
AMG_RL is offline
Old 07-08-2011, 07:13 PM
  #117
Suvneer's Avatar
Thank you sir!!
I have 50 E55 front lip back in stock. Wait, I have 48. Just shipped 2 haha
Suvneer is offline
Old 07-26-2011, 11:30 AM
  #118
Gus83's Avatar
2009 E63
install process has begun, im taking pics and will post them later on today
Gus83 is offline
Old 07-26-2011, 02:42 PM
  #119
Jasoneo5's Avatar
W211 E55
Please PM me your paypal address!
Jasoneo5 is offline
Old 07-26-2011, 04:26 PM
  #120
Gus83's Avatar
2009 E63
Gus83 is offline
Old 07-26-2011, 07:03 PM
  #121
Gus83's Avatar
2009 E63
Gus83 is offline
Old 07-26-2011, 07:08 PM
  #122
Suvneer's Avatar
You don't mess around.
Suvneer is offline
Old 07-26-2011, 07:17 PM
  #123
Gus83's Avatar
2009 E63
LMAO!!! hell no, i really want to make sure this thing stays on and the only way for it to come off is if the front bumper comes with it
im going to give a detail explanation now if thats ok with you
Gus83 is offline
Old 07-26-2011, 07:45 PM
  #124
Gus83's Avatar
2009 E63
parts:
(6) 1/4" x 1.5 bolts
(6) self locking nuts
(1) black spray can
(1) clear sealant or which ever color you prefer
(1) double face tape
(1) 3/4 x 36" aluminum plate
- you have to cut the alum plate into 12 pieces making 4 considerably larger than the rest to be placed in the middle of the lip.
- drill them in the middle of the plates with a 1/4" bitt, and two of the smaller plates need to be first drilled in the center and then they have to be given a significant angle with the bit so it sits ok on the top of the bumper. the possition of the plates is 2 per mounting hole, one under the lip and one on top of the bumper.
- you can spray black the 6 plates that go under the lip and the same for the heads of the bolts, this is only to disguise them from the outside the 6 plates that go on top of the bumper dont need to be painted.
- to 1 plate of each set put a strip of double face tape and this plate will be the one painted and that also the one that goes under the lip spoiler, this is only to give some kind of soft support for the metal not to destroy the lip with vibration.
- the wholes on the lip have to be place in some what of a specific place for the plates to go on easy, after you have drilled them out with the help of someone, present the lip onto the car and with something try to be accurate and mark the bumper where you need to drill. once thats done all you need to put is the double face tape on the top of the lip and then slap the lip on the car, it will take a while so take your time and with patience get it done, also very important dont tighten the bolts to the max because you will damage the lip and make it weak. once you are done with all that is time to put the sealant and let it dry for couple of hours.
Gus83 is offline
Old 07-26-2011, 08:45 PM
  #125
RedBullJnky's Avatar
you to Hate
price shipped to 33027?
RedBullJnky is offline
Quick Reply: Holiday 10 days sales: W211 E55 W211 E63 Carbon Fiber Front Lip $200 SHIPPED!!!
