heat problem..... works on n off ? (help)
1 Post
04 w211 E55
I'm wondering if anyone else had this problem I searched and found nothing helpful. My heat is not working right on my car it, blows out cold air when I have the HEAT highand then sometimes it decides to work. Its FREEZING in NYC and I'm wondering if any1 might have had this issue before ?
2004 E55 AMG
It sounds like the heater control valve has failed or is starting to fail. Happened to me this Summer. The part can be had for ~$50 online and the replacement DIY is on here somewhere. Takes less than an hour, but you do have to remove some plastic and the windshield wipers/motor.
2003 E55 & 2014 GL550
It's not too bad a DIY install but that can be subjective.
If you have very limited experience turning a wrench, it will be a bit of a challenge. More experience doing DIYs and it will take you a couple hours.
W211 E55K, Duc 848
Takes like all of 20 minutes if you have the right tools handy for the job.... the biggest pita is removing the wipers to access the control valve...
