HEADERS GOT CHERRY RED WITHIN SECONDS
Old Jan 1, 2011 | 02:49 PM
skratch77's Avatar
2005 E55
You also have cams,make sure there in spec
Old Jan 1, 2011 | 03:56 PM
jamusa's Avatar
Originally Posted by SuperchargerV8
how did u know your piston ring was ****ed how did u tell what where the signs
The car did not loose any power,but it had a small amount of blue smoke...which i knew was not good,so when i open her up i saw the broken ring along with the scarred #8 cylinder.
Old Jan 1, 2011 | 04:07 PM
jamusa's Avatar
Originally Posted by Roverron
I had a 410 small block Chevy that did that on start up its was timing and it was almost instant that they started to glow. Make sure all of you harness are correct. And that you have the correct file on ECU.
I'm going to send my ECU off to be checked,because i'v already re-checked all the harnesses
Old Jan 1, 2011 | 08:39 PM
AUS-E55's Avatar
CLK-63 BLACK/2014 E63S/2013 ML350
x 2
