Cold weather question related to suspension - help please
My car was an Arizona car until 2 months ago, and has never seen cold weather at all. This evening was by far the coldest day yet this winter - about 5 below.
I have had air struts go out in past, got warning message on dash, familiar with symptoms, etc. However, when that occurred, only the corner the strut was leaking would dump.
Anyway, I left my car parked outside for about 5.5 hours. When I came outside, the whole thing was slammed. I am talking 2-3 inches from ground. I was stunned. So I started her up, and raised the suspension. It raised just fine. I proceeded to drive about 10 mins home with zero warning messages on dash.
Could cold weather cause all air to leak out in such a short time span? I found that odd, and again was quite stunned. Thanks
Twice now - first this morning around 8:30am, I came out to the garage & saw (only) the left rear corner sagged over the tire. Rest of car was normal (though unbalanced.)
Raised her up, then set back to Sport 1, & drove the car for 10 mins to destination. NO error messages on dash to check suspension.
About 3.5 hrs later, came outside to the exact SAME issue. Repeated procedure - raised, set to sport 1, drove. Drove for about an hour, no issues or warnings.
Though I suspect next time I come out to car, it will be sagged again. Opinions please?
Granted there will be some settling in the suspension, but not sagging to either side, that's unacceptable. Have it checked out, because it can develope in a complete collapse. While the car is running the air compressor is keeping air in the system and shock, it's after the car is shut done this occurs. This in itself can cause the compressor to burn out from the constant running, to supply air.
Such is seen with tires when the temperature gets cold outside and your tires look like they're almost flat.
Just a theory.
Just a theory.
At the pressures the system operates at temp delta will not cause the ride height to change more than 1/10th of an inch
EDIT: just read your post about only the left rear tire.. that is not normal, take it to the stealership or any one your comfortable with to look at it.
like AMGPilot said, may be a valve or hose somewhere around the rear
