What should oil quantity reading be in service menu
Ha ha, there are about to be a few less working E55’s when these people overfill their oil and blow a few seals. You guys can believe whatever you want but if you’re going to go off the service menu, there’s a decent chance you’ll overfill. Please double check with a physical dipstick, they’re very inexpensive.
Thanks, I’ll have to order one.
So in order for me to check my oil I have to plug in my entire STAR setup, bring up the DME actual values, and check the car in "Cold Start and Warming Up Phase" --- and I get a reliable reading. Serious pain in the ***. It's one of the most irritating things about this car.
I would recommend a basic OBD reader to pull the sensor data, rather than rely on the dipstick reading. I noticed the dipstick doesn't give consistent results. It's the exact opposite of the transmission tool.
Mike T.
I don't think that tube was ever intended to be used for measuring, and I would be suspect of any measurement that comes off it. Use the sensor data guys.
Also, the OEM tool has a plastic tip on it and my concern would still be that tip would come off inside the engine pan from the heat of the oil.
It's simply not feasible to check the car with a dipstick. I'm so glad my Italian cars have dipsticks for the sumps.
E55 may be different, but I doubt it.
I feel like mine reads 7.8 after doing an oil change with 9 quarts....have to love how something that should be so simple is a mystery wrapped in a riddle.
