Best/Worst of e55 amg?
As others have said, if you plan to take it to the dealer everytime, you are screwed. If you have hook ups other places, you will be fine. The engines and trannies are pretty bulletproof. There are minor things that go bad, like SC pumps($150), SC clutch and parts($900) and on a rare occasion, a strut which you can get rebuilt or replacement parts for around $500. Unfortunately there are a lot of people that have these cars that can't afford them, they buy high mileage cars, mod the crap out of them and then they break. That gives them a bad name. Otherwise, they are solid machines! Oh and try the search button, they did not even make a 07 so go ahead and cross that one off your list.
WELL SAID MARCUS....
And we've also been through this plenty of times on MBWorld: these are not inexpensive cars when new and they aren't inexpensive cars to maintain when used. People buying a used 996 because they're cheap to buy run into the same issue: expensive to fix. Go buy a used Italian exotic or an Aston or a Jag for cheap. Used prices are affordable. Repair isn't.
The rear is a "killer" but not a "real" one. That's because the MB protocol at the dealer is to drop the rear to install. Because the air line isn't supposed to be pulled off the nipple to the reservoir. It's primarily a labor cost. But an Indy will show you how to do it. They don't have to follow protocol like the dealer does.
Show me 7 billion threads of people stranded with Airmatic. Airmatic can fail (like any strut) but you have plenty of warning signals. The few who have reported being stranded never pay attention to the car's behavior and keep on driving when they get symptoms. There are hundreds of thousands of MBs fitted with air suspension. They still use Airmatic on current cars. Where are all those people? On the side of the road?
Being left stranded does not mean "stranded on the road"...you could be left stranded in your house.
You'd be lying to yourself if you think the airmatic system is reliable. I have yet to meet an E-class owner that has never had an airmatic failure ( And I've met quite a few ).
FWIW, I work at an airport and in the parking lot there are currently TWO MB's stranded due to airmatic failure...lol. Just so happens I saw them yesterday...I know it's a lot of coincidence but I found it kinda funny ( and disturbing ).
https://mbworld.org/forums/w211-amg/...c-failure.html
i got mine in september 2004 and it is a 2005 MY.
untill now it has 62k miles. modded like hell and junped through several times on humps.
untill now
non of them have failed.
one of the reasons that i noticed which lead to failure is that if you lower it too much or drive it on sport 2 alot.
most of my driving is on comfort. + never used to ride passengers. most of the time me + a passenger. rarely me + 2 passengers. ^_^
I've never been stranded on the side of the road nor at my home or anybody's home driving a car with Airmatic. Nor have I ever experienced a failure.
So what can I say? That I'm "lying to myself?"
My car isn't lowered, nor do I drive around in Sport I or II very often...
GET ONE and if you change your mind sell it, but you will find it hard to let go of the addiction.
I drove 10 miles with a busted driver air strut on 19's, rubbed the arch when turning. Front was 2inch off the ground.
replacement took me 40mins thanks to the DIY thread.
If you get one just stay away from the stealer and you will be fine.
But no one has mentioned the mod bug?
You need at least 5k$ set aside when this hits you and trust me it will. And be prepared to see that number rise and rise quickly.....
And.... This is where this car kicked my nuts.
So far, my personal experience is that airmatic fails every 4K miles...
You should also poll the S Class forum (ABC is an option on the S, the rest have Airmatic), the R Class, the GL Class, the ML Class, the CLS Class.
But maybe this time around make a poll with mileage, stock/modified, etc., taken into consideration rather than just a fail yes/no. It would be informative to understand any variables involved (like any good poll.)
And I wonder about the Range Rover forums, the Audi forums, the Lexus forums, the BMW forums, the Jaguar forums. They have models with air suspension. I wonder what the stats are on those systems.
The only folks who have the real data outside of random polls in car forums are MBUSA and the dealers. I'm curious why Daimler keeps using this system if it's bad? Maybe Daimler uses Airmatic to get rich off spare parts? Although it sounds like they're shooting themselves in the foot since most Airmatic replacements seem to be under CPO or extended warranty.
p.s., my Indy claims the components have changed over the years and the system gets less replacement rates each time around. Can we assume that a 2009 or 2010 is less prone to failure than a 7-8 year old E55?
