gains for different mods
This should be a summary for gains of different mods...
I´m interested in following gains (numbers):
82mm tb:
kleemann cams:
supersprint long headers:
full cat delete:
168er pulley with ECU:
Thanks for reply!
82mm tb:
kleemann cams:
full cat delete:
Thanks for reply!
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
i will not quantiy the gain here becasue it will start an argument here but i can priortize the order of the approx rwhp gained
82mm tb:3
kleemann cams:4
supersprint long headers: 2
full cat delete: 5
168er pulley with ECU: 1
82mm tb:3
kleemann cams:4
full cat delete: 5
1 Post
2008 ML63 2009 SL63 2010 Alpha 7 GTR
But I did it in the order that Shardul said
Ill give it my best guess from seeing everyone else's transformations:
82mm 20-30
Kleemann cams 15
headers 30-40
cat delete- should go with headers
pulley and tune 50-70
Brabus K8 E55 05
And of course that's an opinion as well, some are saying that headers and cat delete should be numero uno!
82mm 20-30
Kleemann cams 15
headers 30-40
82mm 20-30
Kleemann cams 15
headers 30-40
1 Post
good for you! That's awesome that you gained that much! I was just giving a generalization of hp to expect. And a lot can tribute to dynos, air temp, DA, how hot the car is at the time and the list goes on!
I didnt pick up any power with an 82tb on her,Honeslty.
If I were to do it all over again it would be.
kleemann headers with primary cats deleted
Heat exchanger
Tune
168-178 pulley
Heat exchanger
Tune
168-178 pulley
In my experience as long as you use a MB throttle body all the kits are almost the same besides their appearance (TTM has very clean look ). As long as you port the sc inlet to 82mm then they should all flow the same regardless of appearance. There is just something to be said about the clean look! 35whp for a 82mm TB upgrade is ALOT! I hope I gained that much lol
i have a MB 82mm tb sitting on my desk for months. I have been reading on the kennebell website (they have some good info) as per them a 74mm is good for upto 600rwhp befre it starts to be a restriction. What do you all think about this?
I plan to attach a vaccum gauge to see how much vaccum it is pulling in 3 rd gear on the dyno and then do the same test with a car that has a 82mm TB.
Whatever we're tuning!
I'll let Angelo answer that.
You should see what we are doing to the inside of the TB housing now!
Thanks Ahmad. You are always 100% point on with your information and observations. Using 100% MB parts and port matching are the keys for maximum gains. Knowing the way you always try and reinvent the wheel when you make your own parts, I am sure you are at ~35whp.
All the posts got deleted,but the mess I went threw with my 82tb makes my sick to my stomach even reading people installing them.
I can see it picking up maybe 10-12whp on my car now with a retune but Im happy with the power its making now.
Maybe down the road Ill go with a bigger sc inlet and use a bored out stock or an 80mm tb.
