KILLER CHILLER
Old 02-22-2011, 10:06 AM
rizampi's Avatar
w211 e55 amg
Stupid question...
What happens when I turn the air conditioner to heat?
Old 02-22-2011, 10:14 AM
Roverron's Avatar
ML63
Can you bypass the A/C cut at WOT? In most cars it's a micro switch.
Old 02-22-2011, 10:19 AM
rizampi's Avatar
w211 e55 amg
sorry mr. Roverron, what is the word "WOT"?
Old 02-22-2011, 10:21 AM
Hellzno's Avatar
E55 AMG
Wide Open Throttle = WOT
Old 02-22-2011, 07:00 PM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
Originally Posted by rizampi
Stupid question...
WHEN YOU USE THE HEATER ALL YOU HAVE TO DO IS PRESS THE A/C BUTTON SO IT'S LIT AND YOU GET THE SAME COOLING EFFECT,OBVIOUSLY IT'S COLD OUTSIDE SO THE IAT DIFFERENCE WON'T BE AS LARGE AS WHEN IT'S HOT.MOST OF THE TIME WHEN YOU USE THE A/T MODE THE A/C IS ON TO DEHUMIDIFY THE AIR SO IT WOULD BE WORKING ALREADY.
Old 02-22-2011, 07:14 PM
MBTEK's Avatar
I'M LOOKING INTO THAT,THE A/C COMPRESSOR ONLY DRAWS AROUND 780MA ON MAX DEMAND AND THE PUSH BUTTON TELLS THE FRONT SAM TO VARY THE AMPERAGE DEPENDING ON CONDTION/LOAD FROM THE OPERATOR.FOR EXAMPLE, AT 75 DEGREES ON THE CONTROL UNIT DISPLAY,OUTSIDE TEMP OF 80 DEGREES THE A/C MAY ONLY NEED TO RUN AT 20% OR A LOW AMPERAGE DRAW IN ORDER TO KEEP THE IN CAB TEMPS AT THE DESIRED RANGE WHICH YOU SELECTED.I NEED TO MEASURE VOLTAGE AS WELL AS MONITOR AMP DRAW TO REALLY GET AN IDEA OF WHAT WE CAN DO.
Old 02-22-2011, 11:33 PM
  #32
tbal's Avatar
Haters crazy
Is there any negatives to running this? It sounds too good lol. Will the Ac work normally to cool the cabin still?
Old 02-23-2011, 12:36 AM
  #33
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
engine temps increase slightly 2 - 3 C
thats the only thing i noticed.
but car does always pull hard like when its cold in the morning when your leaving home before warming the car too much.
Old 02-23-2011, 03:24 AM
  #34
tbal's Avatar
Haters crazy
So does the ac work normally?
How much has the custom setup cost you so far?
Old 02-23-2011, 08:18 AM
  #35
chawkins2001's Avatar
2006 E55 AMG
When is this going to be ready for the masses? I want this mod before summer hits us here in the south.
Old 02-23-2011, 10:34 AM
  #36
2006 E55 AMG
sent you a pm Scott
Old 03-01-2011, 10:46 PM
  #37
The Fly 1's Avatar
E-55,IS-250
Any updates?
Old 03-02-2011, 08:31 PM
  #38
MBTEK's Avatar
HIT ME UP WITH A PM FOR ANY ?'S,HOPING TO INSTALL THE RACE CORE IN THE NEXT 1-2 WEEKS AND HAVE SOME LOGGING RESULTS.
Old 03-02-2011, 09:16 PM
  #39
beauphus's Avatar
CLS55 & CL CK60
whats the benefit of race core vs standard? nice work as always scott
Old 03-06-2011, 02:33 PM
  #40
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just a heads up to you Killer Chiller installers. Star Das has quite a few settings for cranking up your AC system. It's used for customers that complain that it's not cooling as good as it should.
Of course it will shorten the life of the compressor but worth it to get back proper running AC after you divert some over to the Chiller in the dead of summer.
Tek knows this already but just for Ali and the other guys putting them in.
Old 03-26-2011, 06:36 PM
  #41
MBTEK's Avatar
I'm installing the race core now,standard core kits available,PM with requests,if I get enough interest I can get a better deal from KC.
Old 03-28-2011, 09:01 AM
  #42
2006 E55 AMG
pm sent
Quick Reply: KILLER CHILLER
