Weight of Stock Mufflers?
I did a search and noticed that some people removed their stock mufflers. For those that removed their stock mufflers, did you by chance weigh them or know their exact weight? Just curious as to how much lbs you would drop from removing the stock mufflers.
PLATINUM SPONSOR
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
