help please...'05 E55
Old Feb 22, 2011 | 10:51 AM
saltydizzle's Avatar
2005 E55 AMG; 2005 CLK 500 (sold)
Hi all, I did some searching on a few forums in the past few days but cant figure this one out.
Earlier this month, I purchased a 2005 E55 with 44k miles (crappy iphone pic included). Apparently, this was BNZUOVR's previous ride. The thing is super clean and has a handful of mods already done (straight pipe, resonator delete, lowered via STAR, rear diffuser, tint ect.) which is great and is what I would have done to it if it was stock. But about 30 min after I took it off the lot, the check engine light came on. I took it to my shop and they ran the codes and stated that it was the O2 sensors that were throwing the codes. They replaced the O2 before the cat first and it ran with no check engine light for about 30-40 miles then it came back on. I took it back in yesterday and they said the O2 after the cat was throwing the code now so I replaced that and drove about 30-40 miles then this morning the light came on again. The car drives fabulous and even my wrench said that it was running perfectly but I cant seem to pinpoint why the light is coming back on. Any ideas? As always your help is greatly appreciated.
Old Feb 22, 2011 | 11:06 AM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
PM Sent!
Old Feb 22, 2011 | 11:31 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
bnzuovr=backyard mechanic......who know what he did to it.
Old Feb 22, 2011 | 11:38 AM
Do you have any idea at all what the source of the light could be? I mean the car drives unbelievable with great power, and from what my tech said, the car was modded correctly and it is super clean inside and out. I am just stumped right now as to what the problem could be...I dont think the straight pipe or resonator delete would throw those codes would it?
Old Feb 22, 2011 | 11:53 AM
emoving's Avatar
No, I have that and headers and mine throws no codes. What code is coming up when they run it?
Old Feb 22, 2011 | 11:58 AM
I am not sure off the top of my head what code # was thrown, just that the codes corresponded to the O2 sensors. I have them at home, when I go home for lunch I will take a look and post it up.
Old Feb 22, 2011 | 12:01 PM
emoving's Avatar
Post the codes and lots of people here will be able to help. Without the x-ray, the doc can tell you whats broke!
Old Feb 22, 2011 | 12:10 PM
Just called up my shop...
Codes are as follows:
P200C-001 (right O2 before cat)
P200E-001
P200E-002
If any one has any ideas I would greatly appreciate it.
Old Feb 22, 2011 | 12:13 PM
emoving's Avatar
Hmmmmm....wonder if its a crank position sensor.
Old Feb 22, 2011 | 12:27 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Doesn't the car unexpectedly die when the CPS is the culprit?
Old Feb 22, 2011 | 12:35 PM
emoving's Avatar
Mine just failed to start right away on time. It only has 19k on it so I took it straight in. In ran great otherwise. They replaced it and said that is what is was which is also what I heard from a few here. It also set the ck engine light on.
Old Feb 22, 2011 | 02:48 PM
I guess I will have them check the CPS the next time I am there probably next week. If anyone has any other ideas I would appreciate it greatly.
Old Feb 22, 2011 | 02:49 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
Always running your god damn mouth one day that mouth of yours is going to be put in place.
Anyway Salty i drove my car in there without any problems no codes no nothing thats the honest to gods truth everyone on here already knew i had engine issues and i swapped the motor as well as you do when i spoke to you over the phone. After having my unfortunite situations with fluid motor union I purchased a 2nd hand motor. After installing the motor at my shop it then took it to Hoffman Estates mercedes had the ECU reflashed and downloaded with the factory software also had them check the entire car over before i took the car. I was told the car was in perfect running order only thing i had were a few bad coils off the motor installed after i swapped out the coils i had not one issue with the car i even drove the car to Washington IL 2 times on NEW Years eve. If you have any other questions please don't hesitate to call or message me.
Old Feb 22, 2011 | 03:00 PM
bnzuovr's Avatar
Again this is coming from a Man or should i say boy who bought his car that someone else did all the work to. I bet your dumbass has never seen a wrench in your life time. SO before you go talkin crap get your facts straight.
Old Feb 22, 2011 | 03:05 PM
Forrest Gump 9's Avatar
shrimp boat
I don't know if the car have the cats deleted or not, that may be the cause. I had hi-flow cats on my car and the O2 still throw code. I should have had my rear O2 deleted when I had the car tuned. Good luck with your car.
Old Feb 22, 2011 | 03:19 PM
ENDSMTG's Avatar
Uh oh!
Old Feb 22, 2011 | 03:22 PM
bnzuovr's Avatar
The rear cats and resinators have been deleted but there are no O2 Sensors that run behind the secondary converters only the primarys guys correct me if im wrong but i don't and havent had any check engine problems on either one of my AMG'S before?
Old Feb 22, 2011 | 03:28 PM
skratch77's Avatar
2005 E55
are the primary cats in place?I thnk chawkins just did a res delete and its throwing codes.Maybe its the colder weather and the car is running to lean.
I did a quick search and the egs comes up with one of the code,check the secodary air pump system to see if its working right.
In the summer the car would probably be ok without the secondary air working since its warm out and the cats dont need it.
Old Feb 22, 2011 | 03:44 PM
The primary cats are still there and have not been deleted.
Old Feb 22, 2011 | 03:47 PM
No worries man, i believe you. No need to get upset, Im sure I will get it ironed out. I am just trying to get as many opinions as possible so I have some ammunition to take into the shop with me.
Old Feb 22, 2011 | 03:49 PM
Great, thanks for the info. I will have them check this as well the next time im in there. I'll also be mounting my aftermarket wheels soon too so more pics to follows.
Old Feb 22, 2011 | 03:54 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just shooting in the dark here, but I know that the factory tune is so friggin precise/picky, it's gotta be looking for those cats/levels in a certain way and not seeing them.
Wish we could get an aftermarket tune back on her.
I just know that when cats get deleted, usually you gotta tune her or it's CEL city.
Lots of stories of guys on here trying to fool the ECU after installing headers and losing time and time again to the ECU of death.
Hope this helps a touch.
Old Feb 22, 2011 | 03:57 PM
Yes this does, thank you very much. This is the next mod I will do in the late spring sometime so it will definitely be tuned up. My wrench said the same thing, that the light could be coming on because of the reflash.
Old Feb 22, 2011 | 05:09 PM
bnzuovr's Avatar
Not upset just don't appreciate people running there mouth like Emoving, He is the last person i would want to take advise from about these cars every other person on here is very knowledgable on here and have givin me great info on these cars that is the reason my car (well now your car lol) was and is in great shape. But that could be right about the tune. If your intreasted i have a flat hood amg emblem i had on the car i could give to you if you like to come pick it up. LOL everything i just typed i just read back to myself and its a mess trying to type and work at the same time doesnt work lol sorry.
Old Feb 22, 2011 | 05:13 PM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Nice Flint Grey FTW!!
