Voltage Regulator Replacement DIY- Its usually not the alternator
#176
What you say makes sense , but I hate waiting for bad stuff to happen again especially battery stuff. I like to get ahead of a problem where possible so I don't get stranded. Well looks like I have to wait too.
#177
Cool .. thanks for explaining, this sounds like my symptoms. I will wait for it to happen and drive to O'Reillys ... almost did that yesterday but the message wasn't there by the time I got close to O'Reillys.
Yes I literally hung around the Oreilly parking lot like a hobo with the car idling till the message popped up again. And yes a load test is what it failed.
And yes when I am cruising, the message does not come on. Also it started to come on more often over the course of 2 weeks, eventually it came on when I was cruising, but goes away and everything is back to normal after a few minutes.
One way I could always make it come on after a while is to go WOT and let off the gas (till rpm dropped below 4k before upshifting) around the last week or so. But after a few minutes it will go off again and back to normal
#178
Easy fix, while you are waiting, get a battery charger! Always charge your battery overnight till you figure this out and fix it. A fully charged battery everyday keeps the tow truck driver away
#179
07 E63 + 07 CLK63CAB
You have to listen to Kponti, he has been down this road before.
Just curious, but you state it is the original alt, what mileage on car. Have you tried to turn on every item that draws current, max fan on heater, headlights, high beams, defogger, radio, AC ,emergency flashers, then with the car idling in neutral check the voltage, then put the car in gear, brake on and recheck voltage. But as Kponti found out it was his alternator. Even when they okayed his alt 3 times after load testing.
#180
I have 89K miles on the car. The only additional loads I had on the car when I got the message are:
1. Dashdaq
2. Onboard camera
3. Music was playing louder than normal
4. AC was on
When the message came on, the Command got shut down as did the camera. After about 5-10 minutes would come back on again
This morning, the only thing that was likely not on was the AC. Everything else was the same. No message this morning
I'll try adding seat heaters, lights, rear window demister etc ... to load it down. We will see what happens
1. Dashdaq
2. Onboard camera
4. AC was on
#181
yes, what I propose is to turn everything on and see if the system will start to shut things down, or what voltage is dropped to while doing this.
Money is on the alt/reg, being the issue.
#182
So I turned everything on in the car, lights, seat heaters/coolers, rear defroster, interior lights, command, A/C on maximum. The voltage drops to 12.3V at idle and gets to 13.5V at lower speeds. Never got the Battery Protection message today at all (except when I pulled the battery terminal while engine running). So regulator now?
I pulled off the battery terminal when the car was running and the car continued to run, so I am thinking the alternator could be OK.
* Edit * Oh I did stop by O'Reilly to check my charging system .. their tester was out of juice …
#183
You have 2 ways to go, replace regulator with OEM Bosch unit into old alternator with 89000 miles. Or the second replace the alternator with a new unit (alternator and regulator). As other have gone they replace the reg, some have luck others are SOL and have to spend further time and money soon after.
Kponti found out that just replacing the reg did not solve his issue, even with the OEM Bosch replacement in a remanufactured unit , it just did not cut it.
Good Luck,
A proper voltage with car running is 14.1-14.2V with everything on.
Side note, we all have done it, removed the battery cable from a running car but DO NOT put the cable back on with the car running, besides a good spark you could do electronic or electric component issues. Seen a neighbour electrician do this and he blew every light bulb in the car that was on at the time he was doing his testing LOL even the dash lights, he should have known better.
Good Luck,
#184
Thanks … I'll just get the alternator .. it's a matter of time I think. I might swap the voltage regulator from the new one just to see if that helps as an experiment …. any good sources for full alternator? Sounds like a reman is not going to cut it?
Good Luck,
Good Luck,
#185
BTW when the "convenience shut off" light is off, the car will pass any test you throw at it. When the light comes on, it will fail
My car is fixed and back to normal, WOT or excessive idling does not bring up any more false codes
I got my new Bosch from Amazon
#186
Just finished installing mine yesterday. Here are some useful notes:
-sizes of nuts on alternator are 13mm and 15mm
-Alternator bracket has (1) screw plus (2) 13mm nuts holding it down
-Voltage regulator has (3) screws plus (1) 15mm nut holding it down
-used this tool to get the screws out due to limited space
#187
e320 stalling at a stop while warm
Hi guys could my problem the voltage regulator I'm hoping some one can help me or should I locate the ovp relay on my e 320 2005 here's a quick run down of what happened for me to think its that acting up so last week I pumped at a new gas station (not sure if that has anything to do with the car stalling) but at first I did. after lots of reading online I think its my ovp relay so Monday I went to work 20 min drive 20 km away and at the lights before the Hwy my car displayed the low battery convenient functions temporarily unavailable then just cut out as if I shut her down so I thought ok boost dead battery maybe I tried cranking it not knowing I was still in drive hahaha noob mistake nothing then I put her in park and she turns no hesitation get to work no more problems then Tuesday no problem Wednesday I'm off so I went to my local pond for some well needed fishing on my way there its about 10 mins 5 km 3 lights from home she stalls out and then I give to gear park crank starts a bit of hesitation not much so come Thursday all good now Friday while in the drive through at Tim Horton she shuts down while I had her in neutral and revving at 750 rpm (thinking its the new gas I put in still premium gas but they only offer regular and premium) ( Canadian tire gas bar I switched cause of the reward points I used to always pump at shell with there v-power premium gas )... so I wait till the lady handed me my coffee and I paid then cranked her up but she started after a bit of cranking one turn of the key but near the end of the turn get to work no problems so its good Friday no work I stay home now sat no problems but I never had to stop at any lights to or from work I timed it out good if it was a red coming up I just slowly approached till it changed now its Sunday Easter Sunday every thing is closed and I wanted to fish but first I idled in my parking space revving at 750 -1000 till it reached full heat maybe 7 mins 5 - 7 mins then I thought it was good till it cut as I was revving so this time I cranked it right away and it didn't start so I put the battery back in my c220 as she was sitting all winter long and cranked he one shot she started lol 1994 c220 love that car about 30 later I start my e 320 to see what happens and starts no problem now here I am any help would be appreciated I'm thinking ovp cause I don't thing its the new gas and also all winter its been a cold one the low battery convenient functions unavailable would pop up most days but then go away 2 mins later I had the battery / alternate checked they said there fine just the battery needed a good charge and that was 3 week ago or so so please I work nights and need to work tonight at midnight and I'm a big diyselfer I would love to avoid going to my indie for repairs she has 120 000 km also I have not pulled any codes yet I don't have a obo ll. Reader also I forgot to mention the check engine light came on the finale time I started it up so I will pull the codes on Monday
#188
p0335 code
#189
2005 E320 4Matic
Thanks, I followed your instruction and fixed the problem on my car, only $40 spent.
The symptom was, the voltage dropped from 14V to 12.5V after 10 min driving. I think the original regulator only work at cold temperate and then stop works at high temperate. I noticed the alternator and the regulator are too near to the exhaust pipe, that's a design problem.
#190
2003 E55 & 2014 GL550
I'm an OG so my baby just sits nowadays.....and remembers years gone by when E55's ruled the 4 Door Planet. Ahhhhh, those were the days.
Proud of our turby brothers though, it's was from us that they were born.
#191
why didn't I think of that oh my God and I was killing myself under the car getting the screws off. and I did it in the summer I was sweating bullets. where did you buy it. it's good to
have for future reasons
#192
SL500
I have flickering headlights and interior lights. I just replaced the voltage regulator and it still didn't fix my flickering lights. It only happens when it's cold out. If I let the car warm up for awhile then it will eventually stop. What should I be looking at next?
#193
Possible BCM. Battery control module.
#194
SL500
Is there any way to diagnose without Xentry or replacement? I've also heard of the connectors becoming corroded and this occurred after I left the car sit for a few months. Both batteries are good. I'm not having any problems starting or consumer electronics going offline though I do have the red battery light. After replacing the voltage regulator I did notice that my dome lights seem much brighter. But it could have been my imagination.
#195
FLGSHP7- it sounds like you are experiencing a power issue. The regulator will "regulate" but can only do this with clean power, you may have a faulty diode, causing a pulsing power signal. Check what the voltage is when the car is running, you may see it is in the 13.5 range.
#196
SL500
Update:
I haven't had the car running for more than a few minutes for three days(it's not my daily driver) but when I went to check batteries the consumer electronics were offline. It may simply be from inadequate charging from the short time the car was idling. I will check again later.
The results were as follows:
Car idling with no auxiliary functions on-
Starter battery 14.09V
Auxiliary Battery 14.09V
Car off
Both batteries read around 12.6 at shutoff and then continue to drop to a little above 12 volts.
Car off
#197
#198
I second the remark about disconnecting the battery. Besides being hard on the ratchet when it grounds and sparks, its hard on the head when you jump and bang your head on the bottom of the car. (There's not much room under there!)
#199
Anyone who works on electrical components with the battery connected should reconsider any mechanical contact with a car. Learning the trade on a Mercedes is costly. Try a lawn mower.
#200
Sorry for tearing up and old thread but I find it pretty interesting as my newly bought e 55 after 2 weeks burned the Alternator / Regulator melted, totally gone installing new OEM alternator pricey but be done with it..
Car died totally died on my on highway had to call road assistance I frk hate it lol anyway no charging both batteries are D.E.A.D new one installed still no charge inspected alternator "Made In China" oh no really all you could have done was tell me is a China alternator well he didnt and is not paying the price, thank god seller has little brain so no problems there so far.....
Problem is me not having any time atm had to leave car at AMG Center huuh and now I am paying the price,, DO NOT Save money on alternator (Never install CHINA Made on a Fk AMG" is all I can say else buy a china car..
