MB WORLD Help need insight.....PLEASE.....
http://www.mickeythompsontires.com/s...StreetRadialII
Then... go to tirerack.com and start searching for a proper front that'll match up with your rear tire. Looks like your best match will actually be a 245/45/18 front.
Example:
http://www.tirerack.com/tires/tires....Z1SS&tab=Specs
Good luck with your search.
FWIW if you plan on driving to/from the track on the M/T's, you won't have them for long. They wear out very quickly. Also they do not handle rain very well. I spun a car around on the interstate going 45 mph in the rain. The car seemed stable until a big rig passed me. The back end immediately came around. I'll never drive with M/T DR's again.
Example:
So Far I gather that A taller tire is needed in the front. Understood, Now the question is how far off can I be (height wise of the rear's??) What Iam saying is how touchy are the tolerances.... I measured my back tires mounted last night at about 26''. Fronts 24''..... So I have to be carefull how tall I gop on the front because of how low my car is to begin with.
So I disconnected the battery for about an hour, Then took the car out after hooking it back up. I noticed the ESP malifunction light came on but no ABS light. I drove stop and go for 20 mins with no problems!!! Thought all was good went home and parked it. then I got in my car to go to work this morning and as soon as I got around the corner both lights came on and It went into limp mode
-How could it work fine and then you shut it off and it sits overnight and has problems in the am?
-Iam still trying to find the right tire combo to match the rears I just figured since someone mentioned the battery reset I figured I would try it.
2. Go into DYNO
MODE and switch everything off....3. Hold down the brake pedal slightly with your left foot.
4. Floor the gas pedal with your right foot 15-30secs.............
5. Repeat steps 3 and 4 until the error goes away........
Apologies, but just could not stop thinking that this was a good solution........
2. Go into DYNO
