Need E55 motor
Old Mar 16, 2011 | 04:45 PM
ebetts55's Avatar
2006 E55
Need E55 motor
Looking to buy a complete E55 engine 2003-2006 , mine blew apart. Nothing over 75K please.
Old Mar 16, 2011 | 04:55 PM
wally AMG's Avatar
MB
blew apart? what mods you have before engine blew apart?
Old Mar 16, 2011 | 04:57 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Speak to Bruce @ TTM i know he has a 55 drivetrain .
Old Mar 16, 2011 | 05:11 PM
ebetts55's Avatar
2006 E55
Wally, I have no mods bone stock blew 81miles after a camshaft sensor and alternator were installed at a local MB dealership.
Old Mar 16, 2011 | 05:13 PM
ebetts55's Avatar
2006 E55
malakasnyc could youu give me more info on how to find Bruce, thanks. Also need a good shop pref with a dyno to install it I live in Bethlehem PA
tbal's Avatar
Haters crazy
That would cause the motor to blow up??? Something doesnt quite sound right.
Old Mar 16, 2011 | 05:15 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
^ +1
Old Mar 16, 2011 | 05:22 PM
ebetts55's Avatar
2006 E55
Where is ttm
Old Mar 16, 2011 | 05:25 PM
slownrusty's Avatar
'06 E55 K2
How many miles were on the car? Also did you speak with the dealership seeing they were the last ones to work on the car (curious to hear how MB would response to something so catastrophic?).
Very strange phenomenon giving your car is stock..
Old Mar 16, 2011 | 05:27 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
blew apart is a loose term. Please descirbe the damage for example of ring lands failing, hole through the piston etc.
Old Mar 16, 2011 | 05:35 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Originally Posted by ebetts55
Where is ttm
LONG ISLAND NY
TTM Bruce
631-420-1500
Old Mar 16, 2011 | 05:38 PM
randallaguirre's Avatar
2010 Silverado, 03 H2, 66 Nova SS, 03 E55
When you say blew up, can you be a little more specific? Are you sure it's in the bottom end?
Old Mar 16, 2011 | 06:06 PM
ebetts55's Avatar
2006 E55
Blew up as in 2 rods came out oil pan.
Just spoke with Bruce at TTM, great guy, soon as I find a complete engine to purchase he will be putting it in. Hopefully someone will have a nice one for me.
Old Mar 16, 2011 | 06:35 PM
grantwoodtx's Avatar
GLE 63S
Did you ask the dealer to explain why this happened after they touched it last?
Old Mar 16, 2011 | 06:47 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I have one that I sourced for myself that has 72k on it for $8500 plus shipping. Send me a PM and I will give you details since I need a few pieces off of your blown motor for a special project...
Old Mar 16, 2011 | 06:59 PM
ebetts55's Avatar
2006 E55
Yes I did the dealership said they installed a new alternator and camshap positioning sensor they didn't touch motor, they dont care they are the dealership.
Adianaty,I found one with 55,000 for $9000.00 delivered kind of high I just missed one on here with 56,000miles for 7000 and was local that i could have picked up. I have my old motor still your welcome to buy anything thats good still off of it evrything but the heads down is in good shape I think an injector went so I'm not going to sell them.
Old Mar 16, 2011 | 07:09 PM
Craigo's Avatar
You have PM.
Old Mar 16, 2011 | 07:11 PM
adianaty's Avatar
Thanks and I'm glad you found one. Its the golden rule of when you need something it always ends up being more than what you expect to pay. I sent you a PM since I only need a couple of the pulleys off the blown motor so PM me back what you want for them shipped to 91326. If you need pictures to describe them better let me know. Thanks!
Ali
Old Mar 16, 2011 | 09:10 PM
BenzoBoi's Avatar
Super Moderator
W221
Dang...hope you're able to get everything worked out!
Old Mar 17, 2011 | 10:25 AM
I don't believe in coincidences. And motor blowing up 81 miles after picking your car up from service is too much of a co-inky-dinky.
Before you take anything apart or touch what the dealership might have caused...
After crank trigger sensor is replacement, does anyone know if there is a process for the ECM or PCM to relearn or reset baseline timing-- or if the replacement of the CTS can cause extremely advanced timing?
How did the car run after leaving dealership? Was it sluggish, or "pinging"?
Did you have any noises BEFORE motor grenaded? Excessive valve train noises, or the "thudding" of a lower rod bearing going out.
I'm wondering in their work they could have removed enough of the air intake/air cleaner housing and possible introduced a foreign object that could have made it's way into the combustion chamber OR have been sucked in from sloppy repair cleanup....
I'd hate to see you drop 12K for someone ELSES mistake or shoddy work.
Old Mar 17, 2011 | 10:38 AM
skratch77's Avatar
2005 E55
well they replaced a sensor that is sensing the position of the crank,that is related to your car blowing up.I would call a lawyer and rain hell on that dealership.
They fed up the install,if the timing is off your car is going to ignite a cylinder when its not supposed to and bam,you get a hole in you block once you in boost.
This is 100% there fault
Old Mar 17, 2011 | 11:34 AM
Normally aspirated cars can handle the timing being off...
Once you supercharge turbo-charge, or do anything to create any pressure greater than atmospheric----ALL THE RULES CHANGE.
Have you checked to see if possibly the sensor has come loose, this could have possibly caused a timing change.
I AGREE WITH SKRATCH, THEY F'D UP THE INSTALL.
Contact a lawyer and align with another shop to do some sort of "engine forensic analysis".
Your car is stock and is not even close to high mileage.
Old Mar 17, 2011 | 11:40 AM
badm's Avatar
2019 E 450 4 matic wagon, cadilliac CTS AWD performance ,2018 VW Tiguan SUV 2006 CLS55 030pkg modded
CAM'S SENSOR AND ENGINE GOING
HAY , I HAD THE EXACT SAME THING HAPPEN TO WIFE'S 1999 S80 VOLVO , IN-LINE 6 . AFTER THE DEALER DID A OIL CHANGE ,,, FOUND OUT THEY SPILLED OIL ON VALUE COVER AND SENSOR UNDER IT . THE DEALER WOULD COVER IT OR VOLVO , DON'T BUY VOLVO'S ANY MORE OR BUY ANY CARS FROM THAT DEALER,,,,, OF COURSE THEIR RESPONSIABLE ,[/SIZE]
Old Mar 17, 2011 | 12:51 PM
chawkins2001's Avatar
2006 E55 AMG
Get a lawyer dude and put it on them.
Old Mar 17, 2011 | 12:59 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I dunno bro, just make sure you do a compression test on ANY engine you buy. At least try to see if you can get it done. Would hate for you to buy a 9K engine and have a slug go out quickly again on it.
Wish you didn't have block damage. For 9K you could buy all new slugs and maybe even a crank. Well at least the slugs.
