DIY: Removing scratches from COMAND screen
Old Sep 15, 2013 | 08:04 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
S.bourdain: It can't hurt to take off the anti glare coating.y screen wasn't like that though.
Old Nov 27, 2013 | 09:37 PM
natta_ns's Avatar
Mercedes-Benz
I have the same problem on my Comand Online in the 2012 E-Class Estate.
Do you think this method would work as well?
Old Feb 8, 2014 | 12:39 AM
ALEN35's Avatar
2007 sl65 amg
bump for a exellente thread!
Old Jan 19, 2015 | 07:47 PM
claudius2000's Avatar
SL550
SL550 COMAND display scratches. Now better than new!
I just finished polishing my COMAND display for the SL550.
It took 10-15 minutes. I used the same polish than GregMB suggested and I ordered the film from NuShield. Very nice people.
http://www.NuShield.com
Email: support@nushield.com
Phone / Fax: (215) 500-6426
(877) 900-9192 x700 Toll Free
Without the film the display looks better than before already. See the attached pictures.
Thanks Gregg!
Originally Posted by GregMB
The title is somewhat misleading.
What most people characterize as scratching of the screen is actually a scratching of the anti-glare coating that is applied to the screen.
Either way, a careless P.O. used some sort of abrasive or overly-aggressive cleaner on the screen and the result is a screen that looked like this:
After a few moments spent on this site and the search function, I found a thread that insisted that this fix was dead-simple and easy to do. The concept was simply to find a gentle cleaner that would remove the remainder of the anti-glare coating from the COMAND screen and give it a uniform appearance.
I bought this package for less than $10 from Amazon.com
OK, Let's begin.... this process is quick and you will literally spend less than 15 minutes completing this repair.
STEP 1: Tape off the surrounding area to prevent getting the cleaners in the crevices where they are not wanted. Start with the #2 Scratch remover...shake well and apply a small dab to a lint-free cloth. The kit I purchased actually included a few cloths with it, but any microfiber cloth would be fine. The smaller the better, so you can get into the small corners, etc.
Polish the screen with gentle pressure, and work your way around the screen until the anti-glare coating is removed completely. Flip the cloth or use a clean corner to clear away the haze as the polish dries...
Here is an "in process" shot....most of the screen has been polished, but you can still see the anti-glare coating in a band across the lower 1" of the screen.
STEP 2: Once you have removed all of the anti-glare coating and polish residue, you can follow up with the #1 Clean & Shine. This one is much more runny and seems to be more like a protective top coat, so most of the real "work" happened in the previous polishing step.
The result is much nicer. All of the scratches are gone, and the screen has a nice uniform look. When powered-up, it seems that the image is noticeably brighter as well. I suppose there may be instances where the screen may be less visible in direct sunlight, but when the COMAND screen is awash with sunlight, no amount of anti-glare coating is going to make it readable.
That's it! This isn't exactly hardcore "tech" but I figured that since this site has already provided me with plenty of answers and information I'd give back in some small way with a project that will probably help a lot of other folks.
It is an easy process to do, and it really helps to freshen-up the look of the screen and keep the interior looking new.
-G
Attached Thumbnails DIY:  Removing scratches from COMAND screen-20150119_162318.jpg   DIY:  Removing scratches from COMAND screen-20150119_150629.jpg   DIY:  Removing scratches from COMAND screen-20150118_132705.jpg
Old Jan 20, 2015 | 09:55 AM
GregMB's Avatar
My pleasure!
I'm glad my simple DIY Tech Article was useful......
-G
Old Jun 22, 2015 | 08:04 PM
MBFamily24's Avatar
2013 Mercedes C250
Car wash messed my command screen up!
Hi,
I have a 2013 Mercedes C250. Will this fix work on my baby? It just happened today and I've been trying to look everywhere to see if my command center screen is glass underneath. But I couldn't really find a lot of info on it. This is my first car and I would really like to keep it nice. I have been having it hand washed and I didn't notice it until after I had been
home and I decided I needed to go to the store and than I saw the scratches.
So my main question : Is the screen underneath the scratch and "protectant" Glass?
Thank you
New Mercedes owner
Old Jun 23, 2015 | 12:12 AM
  #32
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
where did you guys order the novus polish from?
Old Jun 23, 2015 | 12:42 AM
  #33
a100steaksauce's Avatar
W218
Sub
Old Jun 23, 2015 | 02:03 PM
  #34
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
good stuff.
Old Jan 1, 2016 | 10:07 AM
  #35
69armando's Avatar
2011 mercedes e350
Reviving this thread
Just wanted to share that I used that Novus product on my 11GL and I am so happy with the results. It went from close to buying a new screen to just spending $10 and $16 on a screen protector. I recommend this to anyone looking to save there screen and the high cost of replacing it.
Old Jan 2, 2016 | 07:07 PM
  #36
Ejbrock's Avatar
2012 C63 P31 Coupe. 2007 SL55. 1992 911 C2 Coupe
Ejbrock
I just completed the "fix" on my Command Screen. Looks great! I am now going to order a screen saver.
Great Thread!
Thank you
Old Jan 5, 2016 | 08:57 AM
  #37
e500slr's Avatar
2011 E63, 2013 CLS63
Is there a way to get this blue tint?
https://mbworld.org/forums/attachmen...3-101_0813.jpg
Old Jan 5, 2016 | 10:52 AM
  #38
69armando's Avatar
2011 mercedes e350
I would look up Nav Screen protection sheets. I ordered my no glare on eBay.
Old Jan 5, 2016 | 12:55 PM
  #39
Ejbrock's Avatar
Ejbrock
69armando,
I went to ebay and found the Nav Screen sheets.
Thank You
Old Jan 5, 2016 | 01:09 PM
  #40
69armando's Avatar
2011 mercedes e350
Originally Posted by Ejbrock
Ejbrock
69armando,
Thank You
Good, always glad to help out a fellow Benzer...
Old Mar 22, 2016 | 12:24 AM
  #41
Crc4430's Avatar
2014 Mercedes Benz E350 Formatic
Same process, now the screen on my 2014 E350 is almost like a mirror, looks great. To remove AR from the corners I used one of those HID cards (the kind used for parking lots and office doors) and wedged it against a microfiber towel and carefully cleaned the corners. Waiting for screen protector to arrive.
Old Mar 22, 2016 | 02:29 AM
  #42
Jelanib's Avatar
2004 E55 AMG
Nice write up!
Old Apr 1, 2016 | 05:19 PM
  #43
Grossi's Avatar
2014 c63 AMG w204
Thank you for this. Going to try assp!
Old Apr 1, 2016 | 08:28 PM
  #44
pellar06's Avatar
2007 E320 2009 CLS63
Does anyone have any leftover product they would want to part with? My screen needs this done
Old Apr 12, 2016 | 12:54 AM
  #45
SimondoB's Avatar
2011 ML350 Diesel 4 motion
Purchased NOVUS product from Amazon.com. An instant and easy fix.
Old Apr 12, 2016 | 11:00 AM
  #46
Grossi's Avatar
2014 c63 AMG w204
Just got mine off Amazon. It's cheap, I think 11 dollars.
Old Apr 12, 2016 | 01:19 PM
  #47
SimondoB's Avatar
I didn't bother masking the edges of the screen. I was amazed at how quickly the AR coating was removed.
Old May 4, 2017 | 09:55 AM
  #48
MBJM's Avatar
2014 C63 507
Cleaning my car last week, I accidentally touched my Comand screen with a cloth that had Windex on it (I know) and it immediately caused a haze. After much reading, I purchased and used Novus 1 & 2 polishes last night for about an hour. I didn't use a lot of polish but ended up with a screen that became more scratched the more I rubbed. I have attached a picture of the outcome.
The question is, am I scratching the coating and, should keep rubbing/use more product so that I remove it and end up with a clear screen or am I actually scratching the plastic whereby any more rubbing is going to make it significantly worse. I am quite surprised that I didn't get the results which everyone has been posting. Any guidance would be appreciated.
Attached Thumbnails DIY:  Removing scratches from COMAND screen-img_2145.jpg
Old May 4, 2017 | 01:42 PM
  #49
Ejbrock's Avatar
Ejbrock
I would now use Brillianze which is a One-Step cleaner & Polish. Next, I would identify the scratches and use Novus 2 again. The key is to use the products with a very soft microfiber
towel. I maintain my screen with Brillianze. I hope this works for you.
Old May 4, 2017 | 01:47 PM
  #50
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
It seems to me, that you have to go back and use #3, the heavy scratch remover, and then use #1 the cleaner and shiner.
