VIN ground off of motor
Old Apr 15, 2011 | 03:30 PM
azncarjunkie's Avatar
CLS55 black opal
Yeah, sounds shady huh? The guy's story is pretty good as to why there's no VIN where the VIN should be (top of the part of the crankshaft plate is).
Anyone know if there's another location on the block/engine/motor where I can find a VIN that may have been overlooked?
Want to make sure that things are legit or run away if they're not.
edit: not the body or frame of the car, just the engine.
thanks!
Old Apr 15, 2011 | 03:32 PM
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
As a forum member once said on this forum, "If it smells like Trout Get Out!"
Old Apr 17, 2011 | 09:17 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
thanks!
Have not found a VIN engraved on the block proper.
Instead, there’s an 'engine number' on the rearmost upper portion where the transmission’s bellhousing adjoins, which corresponds to MB’s original build sequence documentation.
No harm in using a salvaged block so long as its provenance is on the up and up.
Is this intended for your https://mbworld.org/forums/slk-class...p-n-slk63.html project?
