Forgestar F14s - Offset & Vibrations?
Old Apr 28, 2011 | 04:42 AM
infantry's Avatar
07 E63. 07 STi limited #606/800
Originally Posted by ASP
oops you are absolutely correct is it 285/30 I used to have t1r's and went cheep this time and bought hankooks, biggest mistake ever!!!
Yep, I love the T1R's compared to the Michelin PS2's in straight line performance. I have a set of hancook ventus v12's or something like that sitting in my garage, for when i rip these t1r's. Damn, so not good tires huh?
Old May 4, 2011 | 02:29 AM
ASP's Avatar
ASP
2016 Freightliner "daily driver"
They are not horrible tires, but horrible tires for my application. I am putting out around 550 at the wheels and they don't hook anywhere as good as the T1r's. Also my car pulls into other lanes under heavy acceleration, which under further research on the forums other people had the same issues with these tires. Good luck
Old May 4, 2011 | 02:43 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
I have had mine for quite some time now in 19" with absolutely no issues. My tires are 285/30 and 255/35 or something like that. As far as the offsets are concerned, you tell them the year and model of your car and they take care of that for you. Hope this helps
Old May 4, 2011 | 01:51 PM
NL007's Avatar
2017 CLS63-S
when you say putting out around 550, do you mean hp? i also have a set of V12 coming soon and chose them for longevity, noise, and overall very good ratings....dont recall seeing any comments on your issue...will need to check again...
Old May 4, 2011 | 02:05 PM
NL007's Avatar
2017 CLS63-S
They use to paint these but now are powder-coated...i hope that makes a difference....
mine were flat black and my buddy's were piano black his also chipped and he got them re-coated.
Old May 5, 2011 | 01:54 AM
ASP's Avatar
ASP
Yes 550 hp is what I was talking about and that's at a minimum, will know the actual numbers on the 13th when I get it re-tuned.
Old May 5, 2011 | 01:56 AM
  #32
ASP's Avatar
ASP
search for the keyword "wiggle" also check this out https://mbworld.org/forums/w211-amg/...ted-issue.html
