*pics* How bad do these rod bearings look?
2003 E55 AMG Silver with Merlot Interior
I didn't know these motors had "cracked rod cap" technology....nice! How about the mains out of curiosity? 2 or 4 bolt cracked? Or standard machined and cross bolted or doweled?
2005 E55 AMG
I doubt the mains are fracture split as they are probably made of steel while the block is made of iron. I have never seen a 55K engine opened up before though but I HIGHLY doubt it.
96 and 08 911 turbos
Fracture split connecting rods are common use on a lot of forced induction or high performance engines due to their strength...but it's not really all that exotic. Even a VW 1.8T has fracture split rods and it's a cheap engine.
#32
These main bearings are in quite good shape, considering they have 145K on them. I have seen main bearing that have been mutilated, and gouged the crankshaft. For the age and wear, this car has been maintained well.
#34
Thanks man!
Thanks for the tip! I will be replacing them
Main bearings are probably in the same shape but these are the rod bearings. I did oil changes every 5k miles I guess it shows.
The rod bearing play should be between 0.022 to 0.067mm max. Will have my test results of the current play before replacement.
#35
Every engine in the M112/M113 family has this technology, from the 55K down to the very tame 167HP 2.6 liter M112 V6 in the C240 models.
